Dim Dip By-pass
37 replies to this topic
#1 Hikari Warrior
Hikari Warrior
  • 69 posts
  • Local Club: No (yet!!)
Posted 28 May 2011 - 06:27 PM
And here's my second question for today....
I believe the photos identify as the dim-dip that was fitted on some cars. They never had any of this new fangled stuff when I was young....
The general consensus, I believe is to by-pass it.
Any body done this, and how do you do it please?
Thanks again - you're a helpful bunch!
#2 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 28 May 2011 - 06:33 PM
i think you can just cut the green wire to the relay, thus turning it into a non dim-dip car...
#3 Hikari Warrior
Hikari Warrior
  • 69 posts
Posted 10 September 2011 - 10:10 AM
Just giving this a nudge....
I'm sorting wiring out today, and just hoped to be able to confirm exactly what is needed to by-pass the dim-dip.
I do like the idea of just cutting the green wire - seems quite simple!
#4 freshairmini
freshairmini
  • 1,718 posts
Posted 10 September 2011 - 10:41 AM
Isn't dim dip like an MoT requirement?
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 10 September 2011 - 10:54 AM
No, never came into legislation...
Depends if you want to remove the unit completely or just remove the power feed to the headlights when the side lights are on ( this is what the unit does )
If you connect the Blue with Brown trace wire to the Blue/Red wire then the unit becomes completely redundant, if you just cut wires then you will still need the unit, without which your headlights won't work.
Or just unplug the resistor on the wing.
Edited by Guess-Works.com, 10 September 2011 - 10:59 AM.
#6 Yoda
Yoda
  • 1,958 posts
Posted 10 September 2011 - 11:11 AM
seconded on unplugging the resistor.
Its thats simple.
#7 glowpot
glowpot
  • 88 posts
Posted 10 September 2011 - 02:40 PM
If you don't want to cut any wires or remove any components then just remove the fuse. It worked for me.
#8 mgb1978
mgb1978
  • 108 posts
Posted 10 September 2011 - 09:15 PM
Just cut the green wire .......it's that simple.
This is speaking from personal experience on 3 cars with this relay.
If you could also get someone to stand beside you with a 60 second countdown clock while you do it........it really makes the cutting of the GREEN WIRE much more exciting.
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 11 September 2011 - 02:46 PM
I wouldn't say it's the concensus to remove the system at all, lots of people do but I don't imagine it's the norm. For one thing it does quite a useful thing and if the EU make the requirement for day running lights retrospective might become more useful still. People have to remove it if they have LED sidelights fitted or Angel Eyes but for most of us it's just fine to leave it there. It did enter legislation, and was a legal requirement but the EU decided after a complaint from some major manufacturers that it had never been legal for the UK government to make it law. Personally I see no point in removing it.
#10 DannyTip
DannyTip
  • 1,020 posts
  • Local Club: A Series Magpies
Posted 12 July 2013 - 01:20 PM
Sorry to revive such an old thread. I never knew what this system did and have realised it doesn't actually work on my car.
So to simplify fault finding and a clean engine bay is like to remove it all.
If I remove the resistor and relay and connect the 2 wires as per Guessworks post is it simply a case of following back the remaining wires and removing them completely? Where do the remaining wires go ?
#11 tiger99
tiger99
  • 8,584 posts
Posted 12 July 2013 - 02:23 PM
The reason I prefer to remove them, joining the blue-red and blue-brown (which is essential) is that failure of the relay, which is quite common, can cause sudden loss of dipped headlights, and a possible accident. You are safer without it.
Just insulate the other wires so tehy can't short. No need to unpick the wrapping of the loom to get the wires out.
Edited by tiger99, 12 July 2013 - 02:24 PM.
#12 Yoda
Yoda
  • 1,958 posts
Posted 12 July 2013 - 03:25 PM
Since my last post on this thread, i now agree with Tiger99, in the past couple of years, i have had many customers with lighting problems and it is usually caused by the dim dip relay. I now, as a matter of course, simply remove the relay and join the said wires together before even trying to trace any faults and nine times out of ten, the fault is gone as soon as i join the wires. There is no real need to trace the other wires back to remove them. Just insulate them and tuck it all out of the way. or you will be pulling a lot of loom apart for no real gain.
#13 DannyTip
DannyTip
  • 1,020 posts
Posted 24 February 2015 - 10:42 AM
Sorry for the thread bump but i found a picture of what i removed:
Attached File  dimdip.jpg   78.38K   191 downloads
It turned out my system never worked because the inline fuse was all melted.
#14 Ado1379
Ado1379
  • 588 posts
Posted 23 December 2015 - 05:55 PM
sorry to revive an old thread... been chasing a lighting fault for 2 days and it turned out to be the dim/dip relay.
after creating a shorting link with a wire and some spade connectors its all working fine.
my question is how safe is this? i cant find anything for an MoT requirement. how common is it to bypass this? thanks guys!
#15 cal844
cal844
  • 9,576 posts
  • Local Club: TFMOC
Posted 23 December 2015 - 08:10 PM
Perfectly safe to bypass!
