Post The Split Rims
73 replies to this topic
#61 jonny f
jonny f
  • 1,493 posts
  • Local Club: Boxhill Mini Club
Posted 11 March 2014 - 09:44 PM
Do any of the common split rim companies do split rims with an appropriate offset and width to enable me to continue running arch less?
force racing.
I don't think Carl can get a small enough outer, I think I have the smallest he does and I need arches..
I thought he could, my bad.
What about back mounting the outer?
#62 timmy850
timmy850
  • 3,606 posts
  • Local Club: MITG
Posted 11 March 2014 - 09:50 PM
From the website:
Rim combinations are as follows- We now have even more tooling to produce a wider range of rims, now up to a max of 10" wide.
Inner Rims- 2" - 2.1/2" - 3" - 3.1/2" - 3.3/4 - 4"- 4 3/8" - 4 3/4"
Outer Rims- 2"- 2 1/2 - 3" - big 3" - 3.5" - [95mm, Miglia spec outer] - 4"- 4 1/4"- 4 1/2" - 5"
From that I'd reckon you could piece together a set to fit under the body without arches?
#63 LowlyGent
LowlyGent
  • 21 posts
Posted 11 March 2014 - 11:20 PM
From the website:
Since the smallest outer available there is a 2" , even if you ran 2" inner and 2" outer with face mounted centers, your offset would still be too low for an archless car. (10x4 ~ ET 7mm)
These are the 3-piece wheels I picked up for an archless car. 10x4 with high offsets akin to the rosepetals/minilites/steelies often found on archless cars.
10x4 Impul Pro Mesh Group-C Jr.
#64 Miniac86
Miniac86
  • 334 posts
  • Local Club: MOCKZN
Posted 12 March 2014 - 02:54 AM
^^^Those wheels are wicked!^^^
#65 timmy850
timmy850
  • 3,606 posts
  • Local Club: MITG
Posted 12 March 2014 - 05:59 AM
From the website:
I've also found the "big dish 10" section below with the following info. If you had a 3" inner and a 1" outer you could make it work... that would be around +25 on a 4" wide wheel
Or 1" outer and 4" inner would be around +38 on a 5" wheel
Individual spun rim widths are, 1", 2", 2.5",  3" and 4".
Customers should look to use either the 3" or 4" rims as inners, and then adding any of the other 5 choices to the outside.
Edited by timmy850, 12 March 2014 - 06:02 AM.
#66 LowlyGent
LowlyGent
  • 21 posts
Posted 12 March 2014 - 06:28 AM
Yeah, if you can find 10x1" , 10x0.5", or 10x0" lips, you should be able to make it work.
#67 Shukran
Shukran
  • 129 posts
Posted 20 March 2014 - 03:49 PM
Force 13 x 7 -9
#68 Jayme 1275
Jayme 1275
  • 488 posts
Posted 21 March 2014 - 08:03 PM
Force 13 x 7 -9
They are sweet, would love to see them on the car when fitted
#69 Shukran
Shukran
  • 129 posts
Posted 23 March 2014 - 07:54 AM
Force 13 x 7 -9
Here they are on the car - the shell is going to be stripped down and built up from scratch with MiniTec subs and a VTEC engine. I could not resist chucking them on though.
#70 Jayme 1275
Jayme 1275
  • 488 posts
Posted 23 March 2014 - 10:44 AM
They look very cool man
Will be an interesting project to follow if you get a build thread up.
Edited by Jayme 1275, 23 March 2014 - 10:44 AM.
#71 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 23 March 2014 - 05:02 PM
Force 13 x 7 -9
there is something absolutly wiked about a standard mini with normal looks with some sweeet rims and arches.  id VTEC it, for sure, but keep the exterior as is.  with them wheels, tub the rear arches and sit it low low low.  will look so so nice!!
and be bloody fast!!!
#72 minimaxie
minimaxie
  • 1,687 posts
Posted 28 March 2014 - 08:49 AM
Hmmmm, I've just bought some Exactons. I'm still undecided whether to run archless on genuine 10x5 Minilites or save up for some Rose Petals...... OR get my Exactons split and painted Connaught Green (same as bodywork) GAH!!! decisions!
#73 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 28 March 2014 - 08:53 AM
Buy my 'speical' splits Max :P I want 12" splits now lol
Defo get rose petals <3
Edited by megamini_jb, 28 March 2014 - 08:58 AM.
#74 minimaxie
minimaxie
  • 1,687 posts
Posted 28 March 2014 - 09:55 AM
Lol then I could have lots of splits!!! :P haha wish I could mate, monies going towards respray now.
Ah tempted! Just over 500 to get Rose petals though :(
