Year: 1991
Description of problem (please be as in depth as possible): Suspected head gasket fault
Any non-standard parts that might be involved with the problem? No
Hello there, i know this question has been asked to death but im having trouble collecting information on how to remove the head and replace the head gasket. Ive had all the symptoms, oil in coolant and low compression (really slows down on the motorway, cannot do over 50mph!). I need to change a few things in the engine anyway, and being a 90,000 mile car, i might as well replace it. This will be my first major job on my mini, so i need to know what im doing before i muck it up or something (helped with a K series head gasket change, but thats a completely different engine!).
I have the Haynes manual, so is there a section in purely removing the head and changing the gasket? Also, ive head you need to the clean the head before renewal, how would you do this and what do i need? I have seen the youtube videos on how to change a mini head gasket, but its a bit hard to follow!
Thanks, Alex
