Air / Fuel Ratio Kit
41 replies to this topic
#31 Racer_Pete
Racer_Pete
  • 2,492 posts
Posted 28 May 2011 - 09:36 PM
thanks
#32 Ethel
  • 25,919 posts
Posted 28 May 2011 - 09:54 PM
I think Dave meant perpendicular, not parallel. I've read somewhere that about a metre is considered the optimum distance from the exhaust valves. I've just managed to squeeze one infront of the selector box (my car is GRP, not standard Mini). I reckon this would be better as the pipe is still offset to go around the selector. I'll be cutting a hole so the sensor can be unscrewed through the floor, the cable would be a very tight fit anyway without it.
My thought with sensing just one side of an LCB is you could monitor the most critical pair of cylinders, I'm not sure which that would be, the inners? I guess the downside is something could happen to the other pair and you wouldn't know.
I wonder if you could build a simple comparitor circuit so you could use a lean lambda value to interrupt a temperature sensor signal to the MJ? You might manage to use the MJ auxilliary input for engine warm up as well then, by setting one of the bins to zero or five faults and making that the output from your comparitor.
The sensor bosses are plentiful on Ebay, either as weld ons or in a short length of pipe you could
U clamp in.
#33 minotaur
minotaur
  • 39 posts
Posted 28 May 2011 - 10:35 PM
heres a vid
#34 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 30 May 2011 - 08:34 PM
Justto follow what morley has said Just bought one of these gauge kits rage performance in the states. Got it within 2 days Fedex. Works well. Fits the existing lambda sensor hole if you already have one that is.
Edited by HUBBA.HUBBA, 30 May 2011 - 08:36 PM.
#35 minotaur
minotaur
  • 39 posts
Posted 31 May 2011 - 05:07 PM
mine arrived after 2 days fedex , incredible!
#36 Mini Manannán
Mini Manannán
  • 2,856 posts
  • Local Club: man Estate
Posted 21 April 2015 - 03:48 AM
bought an AEM for my mini years ago and haven't been for a rolling road tune up since, saved myself a fortune in the long run by profiling the needle myself and monitoring with the wideband.
Blasting in from the past but the info is still valid...
I've just installed an AEM wideband AFR gauge, we don't have a rolling road here so I figure this is about the next best thing.
 I'm wondering if people are using these with a logger for TPS, MAP, RPM or even SPLOD etc?  If so, which logger, bearing in mind the AEM outputs 0-5v?  I don't want to spend a fortune on a logger but something that could compare the AFR and at least one other.  Oh, and a long shot...  If I could make it output directly to a Mac lappy would be best of all...
#37 Mini Manannán
Mini Manannán
  • 2,856 posts
Posted 21 April 2015 - 06:21 PM
Anyone?
#38 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 22 April 2015 - 07:26 PM
I just made a mental note each time
#39 Mini Manannán
Mini Manannán
  • 2,856 posts
Posted 22 April 2015 - 11:46 PM
That's what I'm doing at the mo' and I'm getting dialled in slowly.  It'd be nice to be able to log a comparison though.
#40 Ethel
  • 25,919 posts
Posted 23 April 2015 - 01:41 AM
S'pose the cheapest would be to just vid your gauge with a timestamp.
http://www.14point7.com/products/idash
#41 Mini Manannán
Mini Manannán
  • 2,856 posts
Posted 23 April 2015 - 03:42 AM
er... Well the price is OK and it'll run on a Mac  :highfive:
#42 Mini Manannán
Mini Manannán
  • 2,856 posts
Posted 24 April 2015 - 12:37 AM
I'm getting close on my mixture now after days of averaging out the numbers on the gauge, I'm getting close now, I've established that I need a needle that doesn't exist :-)
