Me likey
Austin Mini Van Bare Metal Rebuild
#1426
Posted 20 November 2015 - 07:21 PM
#1428
Posted 21 November 2015 - 07:59 PM
Well the tank doesn't fit for some reason.... Same tank, same hole, with or without foam.
#1429
Posted 22 November 2015 - 08:33 AM
oooo more shiny bits
#1430
Posted 22 November 2015 - 06:37 PM
Just out of interest how far out do other peoples fuel tanks stick out? If that make's sense...
It seems to me that it's fowling near the filler neck and doesnt go high enough through the body.
Edited by SAL 821X, 22 November 2015 - 08:28 PM.
#1431
Posted 22 November 2015 - 07:30 PM
I can get a picture of my estate fuel tank filler tomorrow if you like?
#1432
Posted 22 November 2015 - 08:29 PM
Just so i know what i should be aiming for.
#1433
Posted 22 November 2015 - 10:18 PM
It's not much, 3/8 of an inch or so, if that.
#1434
Posted 23 November 2015 - 11:53 AM
Really right ok so it's coming through the body enough just doesnt seem to want to line up with the mount points.
I do wonder now if the valence is bent....
Bugger
#1435
Posted 23 November 2015 - 04:59 PM
Completely forgot to take a pic today sorry, I'll set a reminder now. I know mine was a swine to get the mounts lined up and then to get the rubber collar on.
#1436
Posted 23 November 2015 - 10:02 PM
No worries
#1438
Posted 04 January 2016 - 03:54 PM
Sorry guys not been on here for ages.
Took a quick pic today, not sure if it'll help. As I said, it's tight!
That helps loads cheers. This is about where the neck of my tank fits through at the moment.
I'm on my 2nd attempt and about 5 hours of trying to get it to fit now!
I even slit the rubber to see if that made any difference but sadly not.
I picked up a trick on a facebook group the other day, someone mentioned about using 2 trolley jacks and jacking it up into the hole. So I'm going to have a go at that for my 3rd attempt.
Ordered a few bits mainly manifold and exhaust so at least I've got everything to try and start it now as well.
#1439
Posted 04 January 2016 - 05:58 PM
My fuel filler neck is very tight on clubby estate but havent had that out yet so not sure why its like that... had to slit the rubber to get it to fit half way well...
Looking forward to another update :)
#1440
Posted 04 January 2016 - 06:53 PM
Mine was a complete barstardo to get in. Something I picked up when I was researching the easiest way to replace my windscreen seal was KY jelly. It certainly helped with the windscreen and as there's no petroleum products in it it doesn't 'melt' the rubber.
