Austin Mini Van Bare Metal Rebuild
1693 replies to this topic
#1096 Gadgets
Gadgets
  • 471 posts
Posted 16 November 2014 - 01:51 PM
ummmmmm nice work
#1097 Minidarren83
Minidarren83
  • 1,207 posts
Posted 16 November 2014 - 03:18 PM
Is the bad fitting with the hinges and door lock fitted sal? They will help pull it in massively
#1098 SAL 821X
SAL 821X
  • 1,890 posts
Posted 16 November 2014 - 06:04 PM
Cheer Darren.
Had another play with it today. I didn't manage to get the door lock on in the end, the hinges are brand news so hopefully that help.
I sat on the inside of the car and felt around the door. I noticed that at the bottom of the door there is hardly any gap between the door and door step. So I bent the flange on the door step in towards the inside of the van.
I refitted the seal and the door now sits further in.
Which is making me wonder???
I'm also wondering if the door skin might need shaping near the pillar.
Pictures to folllow.
#1099 SAL 821X
SAL 821X
  • 1,890 posts
Posted 17 November 2014 - 10:23 AM
Right then bit late but pictures.
Door without seal... Nice... I'd also put the hinges back on after this picture.
8CC425D7-6866-4CF1-90B3-8027B89FB30D_zps
Door with seal.... not NICE!!!!
E9910004-74E0-4F74-AA27-5091E6DB354F_zps
I then as above bent the flange on the door sill inwards and it made it a bit better but forgot a picture of that.
IN OTHER NEWS.....
Old v New. I had to weld a nut to the flywheel bolt to get that out.
E56A3CD3-F679-4331-84DF-D3C1626F5037_zps
New shiny. However the nut on the end is smaller than the old one which means I haven't got a socket to torque it up at the moment.
F7726FE0-7677-44E4-B7F7-658EFA71D5FA_zps
Skimmed the rear quarter again and its getting much better now.
0439F555-24DF-4AC0-9922-9B643B9D4419_zps
Also skimmed the scuttle end and the wing.
B5C451D0-4767-4C2B-A4CA-ED2E2797F11A_zps
Then blocked both back with 80grit and dusted with some black. I will then go 120grit to see how level it is.
8B5B94AE-92DE-4E50-9F46-9BA87DC399F1_zps
DF6268B2-8F31-41AE-A892-A7599FEF5141_zps
I then had a sit in the van and made brum brum noises.
EC4E6416-0617-43B8-9110-D5166CBE64A0_zps
Thats all folks.
#1100 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 November 2014 - 12:13 PM
I would flat the black guide coat off with a 180grit paper as it will even out the highs and lows as you sand.
1200 will just take the guide coat off.
Looking good though! Shame about the door though, wonder why it is like it?
Can you not remove the rubber, close the door on the latch so it sits flush and then  measure from the inside of the door frame to the lip that the rubber fits on and then get someone to measure theirs and compare?
At least you will know if it's the body or the seal then. Might be the wrong seal perhaps?7
Ben
#1101 SAL 821X
SAL 821X
  • 1,890 posts
Posted 17 November 2014 - 12:51 PM
Ben
That's just it Ben. There is no gap at all?
I tried that, took the seal out, put the door back in, felt under the door where the door frame and lip are.
There is no gap at all.. the door butts up against the door frame. I would have thought that there should be a couple centimeters there like it is at the top of the door.
I'll try and get a picture next time I'm over might make more sense.
I did think it perhaps might be the wrong seal I'll look into that.
This is the style seal I'm using at the moment.
9FABD187-ED26-46CA-87BA-4024A60849F1_zps
#1102 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 November 2014 - 02:43 PM
There should defiantly be a gap mate. about 18mm i think!
Wonder what's gone wrong there then?
#1103 SAL 821X
SAL 821X
  • 1,890 posts
Posted 17 November 2014 - 03:29 PM
I wonder if the step which I have replaced isn't in the right place or the profile of the step isn't wide enough to allow for the door if that makes sense. Trouble is its the same on the other drivers door. As I bought the steps from the same place so you would imagine from the same tooling.
Found a picture without the door.
48461DEA-3599-49F8-9ED5-2E525540D5DD_zps
#1104 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 November 2014 - 05:11 PM
Looks about right.
I'm stumped without actually seeing it
#1105 jccc78
jccc78
  • 113 posts
Posted 17 November 2014 - 05:23 PM
is it the door skin that's a little to big or to thick ? just a idea most likely wrong lol
is there anther door even just for a reference to try just to make sure .
Edited by jccc78, 17 November 2014 - 05:24 PM.
#1106 SAL 821X
SAL 821X
  • 1,890 posts
Posted 17 November 2014 - 06:28 PM
Good suggestion Jccc78 something else to look into.
I don't have a spare door unfortunately.
#1107 jccc78
jccc78
  • 113 posts
Posted 17 November 2014 - 08:32 PM
is there any member  near buy with a door they could measure or even old door just to let you try ?
#1108 SAL 821X
SAL 821X
  • 1,890 posts
Posted 26 November 2014 - 12:57 PM
Well no progress on the van recently as it was quite frankly doing my head in.....!
Been buying some parts instead though  :D
A1C647DF-8480-4E2D-971C-09E38B716553_zps
Couple more bits for the engine to turn up then I'm good to go to drop it back in.
Probably not the best way of doing things but I've been thinking about trying to get it running over the winter and then get it painted as and when early next year.
#1109 SAL 821X
SAL 821X
  • 1,890 posts
Posted 31 December 2014 - 08:05 PM
Happy New Year folks...
Hopefully 2015 will bring some paint to SAL and she can once again see tarmac.
:0)
#1110 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 05 January 2015 - 01:26 PM
This van is coming along nicely, havent been on for a few weeks, cant be far off the bright yellow finish now can it?
