Austin Mini Van Bare Metal Rebuild
#76
Posted 22 May 2012 - 02:25 PM
http://www.theminifo...showtopic=68079
linked for later.
#77
Posted 25 May 2012 - 08:09 AM
I've ordered some sheet metal so should be able to make a start on the pesky heelboards next week.
Things to do next week.....
1. Learn to weld!!!! hahaha
2. Cut out pesky heelboards and fabricate new repair sections.
3. Strip drivers door
4. Possibly make a start on rubbing back the load bed for primer.
#78
Posted 25 May 2012 - 08:55 AM
#79
Posted 25 May 2012 - 11:31 AM
#80
Posted 26 May 2012 - 08:23 PM
#81
Posted 27 May 2012 - 02:57 PM
#82
Posted 28 May 2012 - 10:22 AM
#83
Posted 30 May 2012 - 08:57 AM
Couple of bits done last night.
Finished cleaning up the door frame ready for the new skin when I can afford them bejesus there not cheap.
Need to repair the split doors in a couple of places but offered them up they seem to fit ok.
Also have the option to go barn door.
I wondered why the brake pipes wouldn't reach to the mounts on the radius arms the other day. Reason was I'd attached them to the wrong holes on the subframe.... donkey!
I've got Friday to Weds off for this jubilee thing that's going on
- Making a start on the heelboards
- Strip the drivers door skin off
- Cut out the areas I need to repair on the rear split doors
Edited by SAL 821X, 30 May 2012 - 09:01 AM.
#84
Posted 30 May 2012 - 08:14 PM
Iwan
#85
Posted 31 May 2012 - 07:13 AM
#86
Posted 31 May 2012 - 08:32 AM
#87
Posted 31 May 2012 - 10:12 AM
It went fairly easy getting the door skin off with the grinder. However I have the feeling that getting a new one on might not be so.
#88
Posted 07 June 2012 - 09:02 AM
The subframe mount seems to be solid so once I have some sheetmetal I'll make a section to close up the hole. In a way I'm quite glad that I've found this out now and not later once I start using the car.
Other jobs completed over the weekend.
- Stripped the drivers door skin, cut out any sections that needed repairing, painted the inside frame with under-seal.
- Under-sealed the passenger door inside frame
- Cut out the rust from the rear split doors ready for repairs to be made
- Put on new longer track rods
- And sheered off one of the bolts that attaches the pedal box to the dash rail. B*llocks will come back to that later
#89
Posted 08 June 2012 - 07:39 AM
You just keep finding things don't you. It's the same here, although not as severe as the picture you've just shown.
Keep grinding away, literally...
#90
Posted 09 June 2012 - 03:17 PM
