Austin Mini Van Bare Metal Rebuild
1695 replies to this topic
#871 SAL 821X
SAL 821X
  • 1,891 posts
Posted 16 May 2014 - 08:59 PM
Shame i havent got the spare cash at the moment.
I have my eye on some other seats though. ;0)
#872 SAL 821X
SAL 821X
  • 1,891 posts
Posted 20 May 2014 - 07:42 AM
Two wheels on my Wagon, awwww there's two wheels on my Wagon.....
797209AA-17AD-482F-BE54-810748A8EFF5_zps
Need to drill the holes out at the front of the subframe so that I can fit the bonnet pins. Other than that it was a right pain to fit on my own but got there in the end.
Radius arms and hubs tonight.
:D
#873 minbin 69
minbin 69
  • 465 posts
Posted 20 May 2014 - 08:41 PM
looking good sal...keep it up and you'll be done before me :thumbsup:
#874 jcslocum
jcslocum
  • 76 posts
Posted 21 May 2014 - 01:10 AM
Doesn't the brake line go inside the front frame member? Maybe for some protection from getting crushed?
#875 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 21 May 2014 - 06:07 AM
Looking good, wheels on thats got to feel good.
#876 l_jonez
l_jonez
  • 1,453 posts
Posted 21 May 2014 - 08:19 AM
Nope, goes across the top as he has it
#877 SAL 821X
SAL 821X
  • 1,891 posts
Posted 21 May 2014 - 10:19 AM
scrap that just read it again.
As far as I know the left to right brake line at the front runs as I have it here.
Edited by SAL 821X, 21 May 2014 - 10:22 AM.
#878 SAL 821X
SAL 821X
  • 1,891 posts
Posted 21 May 2014 - 09:18 PM
Nearly three wheels on my wagon.
D7A1F14F-23DE-4552-8B7C-82F9D2B20663_zps
Also found the old water pump that came off the engine when i took it apart all them years ago.
BEE0B746-9B52-4FF4-AAD5-6E6FBA3CF341_zps
FEAAD2BD-3BF6-44A8-B0CD-E7EFBA9F9863_zps
Its spins freely but does has a tiny bit of resistance. Whats the reckoning to it looking like I can re use it?
#879 DugganC17
DugganC17
  • 359 posts
Posted 22 May 2014 - 09:03 AM
Put a new water pump on. There o my like £20 so you know it's right then and won't have any worries of overheating
#880 SAL 821X
SAL 821X
  • 1,891 posts
Posted 22 May 2014 - 12:07 PM
Agreed but monies a bit tight at the moment and that's 20 quid to spend on other parts...
#881 hoody99
hoody99
  • 699 posts
Posted 22 May 2014 - 01:47 PM
You can only try it and see how it goes then swap it out if need be not a big job. But I know what it's like to save 20 qwid for other things that are needed to get going
#882 SAL 821X
SAL 821X
  • 1,891 posts
Posted 24 May 2014 - 08:42 AM
Right then you pesky wheels.
#883 SAL 821X
SAL 821X
  • 1,891 posts
Posted 24 May 2014 - 10:14 AM
Three wheels on my wagon.
8C3AAFB4-59DF-4525-9C2D-40D29CD3CB8D_zps
And a half. Cant find the castle nut to put the hub on. Will have to order one.
297C9AB7-49EB-4BEA-93E7-DACAC92F4B8F_zps
Right onto something else.
#884 SAL 821X
SAL 821X
  • 1,891 posts
Posted 25 May 2014 - 08:12 AM
Went to the greyhound track last night for the first time ever. Won the first 5 out of 8 races in a row all first place. Paid for the night out and 30quid up.. Happy days :) winnings going towards parts.
So yesterday finished up with...
A28E8F41-CD26-4835-B085-E410EA999602_zps
FC98FEB1-8F28-4237-AD72-20CCF014BB53_zps
Started to knock out and fill some of the many dents in the load floor.
2D9EB1C7-19F6-42D1-A474-33F09CB141B5_zps
Finally managed to get the pedals after having to grind the shear bolt off. Gave them a good soak in WD40 and will clean them up with a lick of paint.
7D63CA4D-F95F-4516-856F-57CB4AE2B227_zps
Lobbed the steering wheel back on so its easier to turn the car if needs be.
1319357E-7836-4C64-AD37-1F9CA806E3DF_zps
Next comes some head scratching time..... The Front end!!!
So offered up my lovely new panel to the subframe.... Massive balls commenced!! Got to cut up my lovely new panel to get this flange off. I guess this would be where it welds to the inner wing normally.
06429715-41B7-47EC-AA81-DA7DE9C48337_zps
Next i set about the bonnet pins and tear drops. As you can see above, I'd attached the tear drop mount to the front panel. However, it became apparent this wasn't going to work as the pin wouldn't go through the hole with it attached to the front panel. So i decided to attach the mount and pin to the subframe instead.
FC7E33FB-E942-42EB-AD52-CC529E387A13_zps
7D623C28-E842-46E4-9B37-45E437F22BBC_zps
I now need to work out how to attach the clip. I think i will either weld it directly over the hole in the panel or make a disc of metal to fill the whole and weld it to that.
E4ACFCC4-F7F4-4886-B59D-C542EEEBC45B_zps
0D792C52-A358-4494-B517-8F4487886C2A_zps
Then need to repeat it on the other side and should be able to fit the front.
#885 SAL 821X
SAL 821X
  • 1,891 posts
Posted 25 May 2014 - 03:31 PM
Major ball ache!!!! Spent all day trying to get the front panel to fit. Offered the wings up and the profiling is all over the bloody place.... Bought genuine wings so it either them or the front panels thats out.
Looks like the scuttle ends are going to have to come off too now. Luckily i have a pair in the garage.
Pictures to follow.
If anyone has any tips now would be an appreciated time to tell me them.
Had enough for today.
