Austin Mini Van Bare Metal Rebuild
#511
Posted 10 October 2013 - 02:17 PM
#512
Posted 10 October 2013 - 02:27 PM
Got ya! I can see that there's is an extra flange on the end that butts up against the heal board on mine so I will replicate this on the one I make.
#513
Posted 12 October 2013 - 12:02 PM
Major balls!!!!
I'm now not sure if its the panel that's wrong, the floor or the load bed.
The subframe is still also out on one of the back corners!!!!!!!
I'm pretty stumped..... :0(
#514
Posted 12 October 2013 - 03:14 PM
Had enough of the subframe today going the pub.
#515
Posted 12 October 2013 - 03:57 PM
This is looking much better now.
Is there much left to do now?
Ben
#516
Posted 12 October 2013 - 05:36 PM
looks like you had some fun today.
#517
Posted 12 October 2013 - 06:02 PM
Ben
Well unless I can get the subby bolted in Ben there won't be much more happening.
#518
Posted 13 October 2013 - 12:50 PM
This is looking good, not long mate as long as those bolts go in your on for a win :) i am always looking for the updates :) itching to get on mine soooooo bad.........
#519
Posted 14 October 2013 - 04:59 AM
#520
Posted 14 October 2013 - 08:22 AM
Yeah tried that hoddy I think the poly bush needs to be compressed more before it will line up totally.
Got a mate coming round on Wednesday hopefully with a spanner or socket to fit.
#521
Posted 14 October 2013 - 11:44 AM
#522
Posted 14 October 2013 - 11:57 AM
Yes this has also crossed my mind.
If I cannot get it in on weds with the poly I will go back to standard bushes and try that.
#523
Posted 14 October 2013 - 04:59 PM
have you tried to unscrewing the bolts abit then fitting the mounts to the body?
#524
Posted 15 October 2013 - 01:53 AM
#525
Posted 16 October 2013 - 08:10 AM
All the bolts are lose where they attach to the heel board and under the floor.
I think that top rear bush needs to compress a little more. I can just about get the bolt in but it's still millimetres out.
I did exert some pressure onto the subframe by standing on it and it lined up better. However I was on my own so couldn't balance myself and try and screw the bolt in the same time.
Does anyone know the torque setting for the big nut on the bushes? I look in the haynes but couldn't see it.
