Austin Mini Van Bare Metal Rebuild
1695 replies to this topic
#316 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 13 May 2013 - 05:04 PM
Good luck then! Get that floor welded in !
#317 SAL 821X
SAL 821X
  • 1,891 posts
Posted 17 May 2013 - 01:45 PM
Just musing for a moment while on lunch yesterday doodling on some paper about switch panels.
For MOT purposes what switches need to be on the dash of a 1982 Van?
#318 SAL 821X
SAL 821X
  • 1,891 posts
I remember that the panel had 4-5 switches but cannot remember what the hell they were.
#319 ChrisCityE
ChrisCityE
  • 418 posts
Posted 17 May 2013 - 08:05 PM
Standard Mini is:
Choke, Lights, heater rear window, brake check, hazards, Heater.
You obviously won't have the heater rear window...
#320 SAL 821X
SAL 821X
  • 1,891 posts
Posted 18 May 2013 - 10:05 AM
Cheers chris that helps.
Not going to run a heater so wont need that either.
#321 SAL 821X
SAL 821X
  • 1,891 posts
Posted 18 May 2013 - 10:07 AM
Next question.
Does the flange on the new floor panel, where it attachs to the heelboard, go on the inside or outside of the herlboard panel?
#322 minbin 69
minbin 69
  • 465 posts
Posted 18 May 2013 - 10:47 AM
inside mate..should be a flange on the bottom of the healboard for the floor pan to sit on
#323 SAL 821X
SAL 821X
  • 1,891 posts
Posted 18 May 2013 - 11:01 AM
Bugger ive cut that off then.
Will drilling some hole in the heelboard and spot weld it do then?
#324 minbin 69
minbin 69
  • 465 posts
Posted 18 May 2013 - 11:35 AM
whoops :lol:
I'd seam weld it as well to give it a bit extra strength
#325 SAL 821X
SAL 821X
  • 1,891 posts
Posted 18 May 2013 - 11:44 AM
Wicked cheers man.
Going ok so far just shaving the new panel down to fit atm.
Grind a bit, try it, grind a bit, try it and so on.
#326 SAL 821X
SAL 821X
  • 1,891 posts
Posted 18 May 2013 - 04:44 PM
Thats as far as i got today.
Still not welded but the fit is proving a pain!
#327 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 18 May 2013 - 05:33 PM
Looking good! Keep on cutting and trying it for size until it fits. Remember if a gap is to tight once you start welding it in you can always run the 1mm cutting disc Along it to make it right again. Better to be tight ;) bigger gaps are harder to bridge lol!
#328 minbin 69
minbin 69
  • 465 posts
Posted 18 May 2013 - 09:12 PM
getting there mate..like Ryan says little bits at a time and you'll soon have a perfect fit .. :D
#329 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 18 May 2013 - 09:56 PM
Matt you really need to lose those oversills. I know we keep banging on about it but it will be for the best bud. You haven't cut the inner sill sections off the replacement floor pan yet???
#330 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 18 May 2013 - 09:58 PM
I must admit I have to keep resisting the urge to repeat this every time I see a picture of them in this thread but I agree completely, they need to go
