Austin Mini Van Bare Metal Rebuild
1693 replies to this topic
#301 CLM
CLM
  • 817 posts
Posted 24 April 2013 - 07:46 PM
Hmm, when I built up my floor which I ended up but welding I left a bit of overlap to start with, got everything lined up bolted down then used a 1 mm cutting disk to slit between the panels 6 inches at a time without unfastening the rest and used some clamps to pull it the last mm into alignment and tacked it. I continued that along the full length and ended up with fairly decent fit.
Chris
#302 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 24 April 2013 - 09:20 PM
Overlap the pieces of metal with at least an inch then use a 1 mm thick cutting disc on the grinder. This gives the perfect gap for avoiding distortion :)
#303 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 24 April 2013 - 09:22 PM
# sorry left a bit out! Double cut through the overlapped edge remove unneeded pieces of metal and weld.
#304 SAL 821X
SAL 821X
  • 1,890 posts
Posted 24 April 2013 - 09:27 PM
I knew there was a reason for cutting the hole smaller than the new panel. ;)
Cheers guys.
#305 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 24 April 2013 - 09:38 PM
Cheers guys.
Yep thats the way ! I would do a pic of it for you but I'm not at home at the moment
#306 hoody99
hoody99
  • 699 posts
Posted 24 April 2013 - 10:01 PM
How I done my floor bud was pretty simple as it's a simple panel
Welded on both sides cut with a 1mm disc as above also
#307 SAL 821X
SAL 821X
  • 1,890 posts
Posted 26 April 2013 - 05:31 AM
A picture speaks a thousand words!
Cheers hoody
Just need to clean the rest of it up now.
#308 SAL 821X
SAL 821X
  • 1,890 posts
double bugger.
Edited by SAL 821X, 01 May 2013 - 12:56 PM.
#309 Gadgets
Gadgets
  • 471 posts
Posted 26 April 2013 - 06:18 AM
Ah brings back "fond memories" Keep going Matt
#310 SAL 821X
SAL 821X
  • 1,890 posts
Posted 26 April 2013 - 01:03 PM
She shall go to the ball.
Just maybe next year!!!!
No! August so I can drive it down to devon for my mates stag and a little southern england road trip.
#311 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 26 April 2013 - 01:04 PM
Yeh and to come see mine!
#312 SAL 821X
SAL 821X
  • 1,890 posts
Posted 26 April 2013 - 01:40 PM
on the to do list matey no worries :highfive:
#313 hoody99
hoody99
  • 699 posts
Posted 27 April 2013 - 10:28 PM
No problem bud it was my first attempt at it so you won't do much worse than my attempt
#314 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 11 May 2013 - 08:26 AM
Any updates?
#315 SAL 821X
SAL 821X
  • 1,890 posts
Posted 13 May 2013 - 09:33 AM
Not a sausage mate haven't touched it since cutting the floor out on the 24th April.
I've just moved house again so that's taken up a lot of time and been away the last few weekends watching Leicester City Football Club. Although, now they crashed out the play-offs yesterday, I've got 3 months to concentrate on the Van before this season starts again.
Aiming to have a good go at getting the floor in on Saturday though so update coming.
Hold tight lads.
