Austin Mini Van Bare Metal Rebuild
#286
Posted 05 April 2013 - 11:23 AM
#287
Posted 05 April 2013 - 12:08 PM
Without measuring I'd say its about 10-15mm at its widest.
#288
Posted 06 April 2013 - 05:32 PM
#289
Posted 22 April 2013 - 07:55 PM
So tonight took the grinder to the floor. Just hope ive measured it right!
#290
Posted 22 April 2013 - 08:15 PM
#291
Posted 22 April 2013 - 09:22 PM
Its a M-Machine van rear half floor that is actually about 3/4s long and ends at the middle of the x-member it seems.
#292
Posted 23 April 2013 - 09:58 AM
As you can see the door frame flange on mine it quite butchered. I feel this might be the reason the outer A panel isn't lining up with inner.
Mine.
Ryans.
Edited by SAL 821X, 23 April 2013 - 09:58 AM.
#293
Posted 23 April 2013 - 06:17 PM
#294
Posted 23 April 2013 - 09:23 PM
#295
Posted 23 April 2013 - 09:32 PM
which ever way you go for Good luck..we'll be waiting to see how you get on
#296
Posted 23 April 2013 - 10:13 PM
#297
Posted 24 April 2013 - 07:32 AM
Think I'm going to leave this section for the time being. I'll carry on with the floor / heel sections and will come back to it when the vans the right way up again.
#298
Posted 24 April 2013 - 06:20 PM
Now a massive hole in the floor.
Not so pretty from the inside!!!!
Thats it for today.
#299
Posted 24 April 2013 - 06:22 PM
I'm a bit tight at the moment and dont fancy dropping 40notes on one.
#300
Posted 24 April 2013 - 06:35 PM
have to admit i didn't seem mine..i went with a 5/10mm overlap on the tunnel edge and welded both sides..i've been useing pop rivets and bolts to hold things in place while i weld it...maybe not the best way of doing things but it's worked for me so far...
