Austin Mini Van Bare Metal Rebuild
1693 replies to this topic
#1681 SAL 821X
SAL 821X
  • 1,890 posts
Posted 05 June 2020 - 06:31 PM
Cheers MM.
Started her up this evening for a while and with the new dip stick the flat spots worse now I'm sure of it lol
Got some of the carpet in too so it starting to feel a bit more comfortable now.
#1682 SAL 821X
SAL 821X
  • 1,890 posts
Posted 10 June 2020 - 09:57 AM
Nearly finished the footwell carpet now and feels much better.
49991279542_5b8c256d8d_z.jpgUntitled by Matt  Locke, on Flickr
49991036271_bc6eee3faf_z.jpgUntitled by Matt  Locke, on Flickr
#1683 SAL 821X
SAL 821X
  • 1,890 posts
Posted 14 June 2020 - 09:29 AM
Swapped the plugs yesterday and seems to have cured the flat spot when blipping the throttle its bogged a bit when its was cold but once warm it was fine. Couldn’t take it up the road though as ive not finished cutting in the carpet round the pedal.
Oil pressure seems to be a bit lower too.
#1684 SAL 821X
SAL 821X
  • 1,890 posts
Posted 25 October 2022 - 05:27 PM
Holy thread bump batman… guess who's back! Well I’m still going at the resto.
Not a lot has happened in the last 2 years the vans mostly been sat under a cover apart from running it up now and again. However, a couple months ago I drove it up the road and when I got back noticed that it was leaking oil quite a lot still. Last weekend we had the engine out and the crank seal was toast!! this has been changed now and no more leaking!
there also seems to be some weeping from the head gasket with water bubbles so that is going to have to come off and be changed next.
It also needs a good tune up as the mixure is all over the place, flat spots and bogs down when you accelerate...
Heyho, it finally feels like it's getting almost road worthly now though.
I also seem to have lot all ability to post images!
Edited by SAL 821X, 26 October 2022 - 11:32 AM.
#1685 SAL 821X
SAL 821X
  • 1,890 posts
Posted 25 October 2022 - 05:37 PM
https://www.amazon.c...3eEAPvncowbVVt5
Edited by SAL 821X, 26 October 2022 - 11:12 AM.
#1686 SAL 821X
SAL 821X
  • 1,890 posts
Posted 26 October 2022 - 11:16 AM
https://www.amazon.c...91ZyIFPzTHlWsfj
Edited by SAL 821X, 26 October 2022 - 11:18 AM.
#1687 sonscar
sonscar
  • 2,985 posts
Posted 26 October 2022 - 01:18 PM
Do I spy oil leaks?or did you carefully park over someone else's?Looking very nice,love the colour.Steve..
#1688 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 October 2022 - 08:45 PM
Good to hear you still have the van!
Good luck worh sorting out those few issues so you can enjoy it
Ben
#1689 SAL 821X
SAL 821X
  • 1,890 posts
Posted 27 October 2022 - 02:32 PM
Yep... that was the reason for taking the engine out....
Popped in an uprated clutch plate while I was at it.
#1690 SAL 821X
SAL 821X
  • 1,890 posts
Posted 27 October 2022 - 03:01 PM
Ben
Certainly been a long time coming.
It's not going anywhere that's for sure.
#1691 Mini Manannán
Mini Manannán
  • 2,856 posts
  • Local Club: man Estate
Posted 28 October 2022 - 12:13 PM
Nice to hear from you SAL, I'd forgotten about this thread!
Imgur is about the best for images, just copy and paste the BB code
#1692 SAL 821X
SAL 821X
  • 1,890 posts
Posted 16 November 2022 - 08:19 PM
Evening all,
So update is that I manage to fix the oil leak with a new crank seal… whoop
However, the heads weeping a little water now! So will need to take the head off and replace the gasket.
Also, swapped the needle from ADS to BCE to see if it will run better. Messed around with mixture but its clear that I’m no carb tuner.
#1693 YoungUn
YoungUn
  • 488 posts
  • Local Club: F.A.B.M.O.C
Posted 21 November 2022 - 04:34 PM
Hi, Where is this carpet from? It looks decent!
#1694 timmy850
timmy850
  • 3,297 posts
  • Local Club: MITG
Posted 27 November 2022 - 09:31 AM
Evening all,
Just checking you know, but those needles aren't compatible with each other unless you change the jet:
ADS is a 0.090" jet
BCE is a 0.100" jet
