Austin Mini Van Bare Metal Rebuild
1695 replies to this topic
#1576 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 04 April 2018 - 03:24 PM
Good to see you back Sal!
#1577 Van13
Van13
  • 314 posts
  • Local Club: Unknown
Posted 12 April 2018 - 05:18 PM
Good to see you back sal I was changing the tank in the 70 and got to wondering about you ,hope the mrs is coping well
#1578 SAL 821X
SAL 821X
  • 1,891 posts
Posted 20 May 2018 - 07:34 AM
Rolled the old girl out the garage for a bit of sun today. And mainly as I needed to clear the garage up a bit before the house goes up for sale.
Sat her ticking over got 10-15 minutes to get up to temp and run in a bit. Noticed that the top hose was stone cold!!!! stuck my finger in the rad and yep that's cold too. So I'm guessing the rads blocked or the thermostat isnt opening.
 0F7AE254-5C0A-4F19-9F87-6F802799198E_zps
75704183-83ED-4CE0-B4E7-6701BA5342D7_zps
F658B800-7611-483D-BC93-D6567BCE906F_zps
I took some video of her ticking over but photobucket wont upload them for some reason.
#1579 Mini Manannán
Mini Manannán
  • 2,860 posts
Posted 21 May 2018 - 08:30 AM
You can't run it in on tickover SAL, you need to run in under load so it pushes the rings into the bore.
Good to see the old girl in the sunshine though.
#1580 SAL 821X
SAL 821X
  • 1,891 posts
Posted 29 August 2018 - 06:22 AM
PROGRESS....! well some anyway.
I've been really struggling to find the time with impending baby to get on the mini. But I had a friend over the weekend offer to help with the front loom and windscreen so it spurred me on a bit.
First time fitting a screen and wow that's a faff!!!! only took us about 3 hours.
Then moved onto bleeding the clutch and brake. But only got as far as bleeding the clutch to find that the clutch isn't working so not sure what's up there. The slave pistons moving but the pin isn't and feel like the clutch pin isn't returning as there no resistance in it what so ever it just move freely back and forth....????
So looks like the bell housing going to have to come off to investigate...
Hay Ho 3 and a half weeks till baby arrives!!!
#1581 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 01 September 2018 - 06:50 AM
Its nice to see that little beast out in the sun light again!
#1582 GraemeC
GraemeC
  • 7,476 posts
Posted 01 September 2018 - 03:06 PM
I'm not sure, but it looks to me like the clutch arm is in backwards
#1583 SAL 821X
SAL 821X
  • 1,891 posts
Posted 01 September 2018 - 03:24 PM
I did wonder if the arm might be in the wrong way round?
#1584 KTS
KTS
  • 2,490 posts
Posted 01 September 2018 - 03:28 PM
..before you remove the bell housing, as well as checking the arm's the right way round, remove and the clutch arm and try and withdraw the release pin from the bell housing.
if it comes out, then you forgot to fit the release bearing (..or it fell off..) :proud:
..obviously you still have to take the housing off to fix it...
Edited by KTS, 01 September 2018 - 03:29 PM.
#1585 SAL 821X
SAL 821X
  • 1,891 posts
Posted 01 September 2018 - 03:33 PM
I also wonder this as the pin with the bolt on the end moves in and out quite freely... I would have thought this would have some tension to it?
#1586 KTS
KTS
  • 2,490 posts
Posted 01 September 2018 - 05:00 PM
..some free travel in the pin is quite normal - it's only when you have your foot on the clutch that the release bearing makes contact with the pressure plate
#1587 SAL 821X
SAL 821X
  • 1,891 posts
Posted 02 September 2018 - 07:37 PM
We talking millimetres of travel or inches as mine is?
I’ve ordered a new release bearing just in case, should come in the week so planning to take a look at it this weekend.
#1588 KTS
KTS
  • 2,490 posts
Posted 02 September 2018 - 08:10 PM
...when you replaced the flywheel bolt, did you remember to put the clutch sleeve back on ?
#1589 SAL 821X
SAL 821X
  • 1,891 posts
Posted 03 September 2018 - 05:54 PM
To be honest KTS it was that long ago I barely remember lol.
#1590 SAL 821X
SAL 821X
  • 1,891 posts
Posted 03 September 2018 - 06:04 PM
Just looked back through some pictures and found this one if it helps?
F7726FE0-7677-44E4-B7F7-658EFA71D5FA_zps
