Austin Mini Van Bare Metal Rebuild
1695 replies to this topic
#1546 carthorse
carthorse
  • 257 posts
Posted 24 May 2016 - 04:54 PM
Sometimes walking away from a long term project like this for a couple of weeks is the best thing you can do if your getting frustrated with it. I know from bitter past experience if you keep bashing on it can lead to mistakes, bad decisions and further pain.
This little vans come so far over the last 103 odd pages of rebuild thread and its within a last smigin of being something you can be really proud of - keep taking little chunks off the 'to do' list and you'll be on the road in no time!
#1547 chrisn89
chrisn89
  • 113 posts
  • Local Club: BOGMOG
Posted 24 May 2016 - 06:14 PM
well things seem to be going backwards more and more.
I no cannot seem to get the facet pump to pump fuel round from the tank to the carb. I realised that I also had the fuel filter the wrong way round.
This is how I have it plumbed in at the moment which i'm sure when I read the instructions is the correct way.
There's power to it as I can hear it ticking when the key is turned to position 2.
I wonder if it's the tank as there is almost 10 litre of fuel in there now.
I also tipped a load of fuel down the carb to see if it would fire. I don't think it's sparking now either as it wouldn't fire.
It was running a peach before I started mucking about with the timing cover and gears.
Back to square one! and more and more doubtful I'll make L2B.
I dont mean this how it sounds but i'm sure you'll know what i mean... but its a relief to see someone else having chew with these! I've had two now and they are excellent. but they seem to get airlocked extremely easy! Trying to get mine running at the moment and every time i need to mess around getting the air out of the fuel pump before i can get fuel pressure back!
Look forward to seeing you have a bit more joy with it! put up with the chew and it'll all start falling together!
#1548 SAL 821X
SAL 821X
  • 1,891 posts
Posted 24 May 2016 - 08:42 PM
Tried to get it started again tonight with a machanic mate.
First thing he noticed i had one shorter push rod. Gods nows how that happened but must have got the mixed up with some others i had in the garage.
It still wont run though. Got spark and sure we have fuel now ive moved the pump to a different angle.
We sprayed some carb start down the mouth of the carb, turned it over and it spat itt all back out the mouth.
It seems that the engine is blowing out the carb rather than sucking in.
If that makes sense?
#1549 Domneon
Domneon
  • 720 posts
Posted 24 May 2016 - 08:59 PM
Got it all timed up right? Cam and ignition timing?
#1550 SAL 821X
SAL 821X
  • 1,891 posts
Posted 24 May 2016 - 09:14 PM
Couple.people on facebook saying its rotor 180 degrees out.
Going to have a play with the leads in different order see if that makes a difference.
#1551 chrisn89
chrisn89
  • 113 posts
Posted 25 May 2016 - 06:51 PM
if you take the filter off the carb can you see the dashpot lifting?
I've had a saga getting mine running and it just turns out the float for the fuel was shutting off too early,
Have you got compression?
#1552 SAL 821X
SAL 821X
  • 1,891 posts
Posted 30 May 2016 - 11:13 AM
Finally manage to get it running again at last.
Trouble is it now sounds like a tractor and the timing covers still leaking oil.
Quick video
http://vid91.photobu...zpsulgf8wkc.mp4
Edited by SAL 821X, 30 May 2016 - 11:14 AM.
#1553 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 30 May 2016 - 04:22 PM
Very Massey Fergie SAL, there's something far wrong there.
Here's Doug Lawson's rocker-box sealing method: http://www.theminifo...king/?p=2962209
Personally, I use one of these: http://www.minispare...|Back to search  I've not had any leaks using it.
#1554 SAL 821X
SAL 821X
  • 1,891 posts
Posted 30 May 2016 - 04:28 PM
When it ran before it didn't make that noise.
Sounds like the flywheel, clutch end to me. I'm going to reset the tappets just in case it might be them clattering.
#1555 SAL 821X
SAL 821X
  • 1,891 posts
Posted 30 May 2016 - 04:29 PM
Just hope its not crank clatter! 😕😕😕😕
#1556 fazz376
fazz376
    Just On Tickover
  • 5 posts
Posted 30 May 2016 - 08:31 PM
Coming along nicely there, good to see another van being saved.
Great pics.
Faz
#1557 fazz376
fazz376
    Just On Tickover
  • 5 posts
Posted 30 May 2016 - 08:37 PM
Hope you get the running problems sorted soon.
#1558 lawrie124
lawrie124
  • 1,711 posts
Posted 31 May 2016 - 04:43 PM
can't see clearly from that picture but are HT leads on correctly (sorry, not teaching you to suck eggs).
if 1 on the cap is pointing towards plug one (nearest water pump end) then clockwise on dizzy they should be on 1,2,4 and then 3.
also, getting dizzy 180 degrees out is a mistake I've made before, as there are 2 TDC's and you want the one with slack on tappets 7 and 8 (furthest from water pump) and rotor should then be pointing at plug 1 (water pump end).
and stick a set of those sparky-sparky testers on the plugs; a set of four is something like £10 from halfrauds and always worth having in your spares box
apologies if you know all this and have done it.
Mike
Edited by lawrie124, 31 May 2016 - 05:05 PM.
#1559 SAL 821X
SAL 821X
  • 1,891 posts
Posted 04 June 2016 - 07:33 PM
Well she's pretty much purring like a kitten now.
This is before I noticed that two of the leads where the wrong way round.
http://vid91.photobu...zpst1kxammq.mp4
Battery cut off and choke cable installed.
Oil pressure looks a tad too healthy???
Still need to sort out the oil leak from the timing cover though but I couldn't face stripping the rad down again today.
Only other thing I did was to fit the horn and tidy some of the loom up.
#1560 Psycho-biker
Psycho-biker
  • 91 posts
Posted 04 June 2016 - 09:21 PM
I can only imagine how relieved you are it runs sweet now!
Keep going! its keeping me going on mine, slowly
