Rally Mini: Head Gasket Repeatedly Blowing/overheating Problem
18 replies to this topic
#16 John Clayton
John Clayton
  • 110 posts
  • Local Club: Colchester Mini Club
Posted 27 May 2011 - 10:41 AM
Iain McGrory reckons a new rad (preferably alloy) would be worth putting on this car
#17 Ethel
  • 25,919 posts
Posted 27 May 2011 - 11:38 AM
It's a one man topic! Good reading though :D
Putting the block 'n head in a caustic tank to remove some gunge and improve the thermal transfer could help, but probably isn't an option. I do wonder about the advantages of leccy fans 'n pumps on a competition car, where your foot will often be flat on the floor making the power (and heat) close to linear with engine speed.
I'd also worry a bit about water circulation in the engine with a switched external pump.
#18 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 27 May 2011 - 07:21 PM
with electric pumps, I wouldn't trust anything other than a Meziere pump on a serious competition car
http://www.meziere.c...860-wp136s.aspx
#19 John Clayton
John Clayton
  • 110 posts
Posted 31 May 2011 - 07:48 PM
I got a bit of advice from a couple of eminent Race Mini engineering firms
Side mounted rad with elec fan
Only suitable for road use –didn’t provide enough cooling on Paddy Hopkirk’s Mini when it got into traffic on the Monte Carlo rally (even at high altitude with the resultant low temperatures)
Front mounted rad
Popular with the race chaps. Requires a swirl-pot but no elec fan is required for racing (for rallying it WILL probably require a fan as you have to drive to the stage start, queue up etc.). This option will probably save 4-5Bhp over a mechanical fan. Just get a new ront mounted rad/fan for a 90s Mini from Mini Spares (approx £200 for fan & rad + temp switch, wiring, piping, swirl pot etc.)
Elec water pump
Saves approx 3 Bhp.
I think my first step is to get the existing brass Rad out tomorrow and get it down to the local Radiator Firm and get them to do their free pressure and flow test on it. They can re-core this Rad (4-core) for just under £100 or they can do a new brass/copper 2-core Rad for about £70.
Edited by John Clayton, 05 June 2011 - 09:20 AM.
