Stunning interior
1971 Clubman Estate....now Turbo
#286
Posted 04 June 2016 - 01:49 PM
#287
Posted 05 June 2016 - 08:02 PM
One of the doors is now finally completed,
#288
Posted 06 June 2016 - 06:19 PM
Stunning Estate you have there Sir,the wood trim along the side really works well with the paint colour.
#289
Posted 08 June 2016 - 11:11 PM
Found a solution to fixing the side trims on. I'm using the plastic alternatives bresco sell and then I used a rubber mallet and very gently tapped the chrome trim to close the gap ever so slightly so that it grips better.
That does look rather nice, that has made me think about keeping my fake wood, you say you got the clips from bresco can you put a link up of which ones they are as went to their site and they have a lot of clips, it would be great help.
#291
Posted 12 June 2016 - 06:50 AM
That looks amazing you must be very pleased with it :)
#292
Posted 08 July 2016 - 07:22 AM
Hi Woodenman23, If you dont mind me asking are those Wood and Picket type arches, and where did you get them from.
Ger
#293
Posted 08 July 2016 - 11:02 PM
I don't mind at all. They are Bullet arches, which were used on some of the German market Sportpacks. You can get them from ABS Motorsport however I did modify mine a bit to get a better fit.
They have been trimmed down so that they suited my wheel set up, as they are pretty wide as standard. I modified them so that the fixings aren't visible, and at the rear of the rear aches I extended them so that they wrapped around the rear valence.
http://www.absmotors...-5-bullet-arch/
Edited by woodenman23, 08 July 2016 - 11:04 PM.
#294
Posted 11 July 2016 - 06:24 AM
Ger
#295
Posted 17 July 2016 - 08:58 PM
This weekend we sorted some wiring issues, programmed the Stack gauges with min/max water temperature and oil pressure levels and cranked the car over (not trying to fire it) to see if it would build oil pressure. It fluctuates between 50-60 PSI and takes 4-5 seconds to get there. Pretty happy and another step closer to firing, need to get a few bits and set fuel pressure.
#296
Posted 18 July 2016 - 05:48 AM
ooo Not long to go until she can fire into life, looking forward to seeing this at some shows. What a stunning car.
#297
Posted 18 July 2016 - 08:08 AM
Soooo!!! envious mine seems so far away! Love this car!!
#298
Posted 24 July 2016 - 05:02 PM
