Gearbox "band Saw" Noise
Posted 23 May 2011 - 05:18 PM
The engine is an 18000 mile 1275 and in all other respects performs faultlessly, the gear change is good too. I was worried that some thing was being chewed
up so I removed the power unit and separated the gearbox from the engine. I was expecting the fault to be obvious as there is alot of fine aluminium swarf in the oil film on the inner casings etc.
I honestly do not know what is wrong as every thing I checked looks perfect and there appears to be no contact between any gears or casings.
Your help on this is much apprieciated.
Many thanks Dan
Posted 23 May 2011 - 05:22 PM
Posted 23 May 2011 - 05:27 PM
Posted 23 May 2011 - 06:48 PM
Posted 23 May 2011 - 07:10 PM
the bearing was pllit and was just sitting there doing nothing
Posted 23 May 2011 - 07:28 PM
Posted 23 May 2011 - 08:11 PM
Posted 23 May 2011 - 08:12 PM
Many thanks Dan
Posted 23 May 2011 - 08:31 PM
Posted 23 May 2011 - 08:36 PM
It should look like this...
I eventually ended up with these.....Problem solved...
Posted 23 May 2011 - 09:00 PM
Dan
Posted 23 May 2011 - 09:12 PM
Posted 23 May 2011 - 09:20 PM
Posted 24 May 2011 - 07:22 PM
The rest of the gearbox is currently in the hot wash tank being totally cleaned up before I delve into it's innards!!
I still can't believe that a gearbox can make a noise like this one does with out any obvious issues!!!!!!!!!!!!!
Posted 17 June 2016 - 02:50 PM
Hi all,
so i am having a knocking noise in my transfer case. i am changing most of the parts that could be causing this. however i have broken the plastic casing for the roller bearing and i do not have a clue where i can find one. can anyone point me in the right direction?
