Location Of 2nd Engine Earth Strap
7 replies to this topic
#1 Ozymandias
Ozymandias
  • 278 posts
Posted 16 May 2011 - 10:33 AM
Model: 1.3 SPI
Year: 1995
I want to fit a second engine earth strap - can I run it between to horn bracket behind the grille and the bracket on the engine which holds the alternator on?
Would this affect the electrics of the alternator in any way?
My engine bay is so full of air conditioning gubbinry I can't access any other places to attach it!!
Thanks for any advice...
#2 minibarnerz
minibarnerz
  • 479 posts
  • Local Club: torbay mc, somerset rusteez
Posted 16 May 2011 - 12:39 PM
Wouldn't be a great place. Can you not get below the engine, from the gearbox to the subframe?
#3 yousmeg
yousmeg
  • 839 posts
  • Local Club: Not yet...
Posted 16 May 2011 - 12:55 PM
Why do you need a second one? :S
#4 Ozymandias
Ozymandias
  • 278 posts
Posted 16 May 2011 - 01:18 PM
It's to ensure that you have the best possible earth connection - belt and braces, I guess - but having an extra engine earth has often helped solve electrical issues (including battery drain, which is why I'm doing it).
#5 mini 4o
mini 4o
  • 318 posts
  • Local Club: corfu mini's
Posted 16 May 2011 - 01:21 PM
hi
why not take it from the gearbox to the subframe, then sub to the body.
john
#6 1995 MK2 IOM
1995 MK2 IOM
  • 810 posts
  • Local Club: NO CLUB HERE.... YET
Posted 16 May 2011 - 01:27 PM
following this problem I had...
clicky
I now have a second one fitted... now I have no worries about earthing!
J
#7 Big_Adam
Big_Adam
  • 7,435 posts
Posted 16 May 2011 - 02:38 PM
Old car I had it from the thermostat housing to the plate that covers the wrong side drive pedal box hole.
Current car has a second from the bell housing to the inside of the wing.
#8 yousmeg
yousmeg
  • 839 posts
Posted 17 May 2011 - 12:29 AM
clicky
J
Oh right, i see.
Ill be sticking with one though, looks tidier
