Dashboard Build
#16
Posted 26 May 2011 - 02:41 PM
#17
Posted 26 May 2011 - 02:43 PM
How much has the suede cloth cost? I haven't seen a picture yet but it sounds brilliant!
The suede was £6.99 per meter and it's 1.4m wide, so enough to do dash and all the door cards like I've done
http://www.terrysfab...n-fabric-black/
Here's what I've done
#18
Posted 26 May 2011 - 02:48 PM
#19
Posted 26 May 2011 - 02:51 PM
I stapeled mine around the back, pulling it tight. Would of prefered to use glue, but it worked
#20
Posted 26 May 2011 - 02:54 PM
#21
Posted 26 May 2011 - 03:18 PM
Edited by DanParsons, 26 May 2011 - 03:20 PM.
#22
Posted 26 May 2011 - 03:21 PM
I want to do this for sure. My only problem is i have checker plate door cards which the previous owner has rivited into the door and i darent take them off because i dont want to shee the holes that the idiot has put in my door. Hopefully i could fashion some door cards from MDF or plywood and give old terry a bell about material. Definitely in the mood for a revamp now.
Sounds good
looks good
Posted 27 May 2011 - 10:46 AM
Mark
#24
Posted 27 May 2011 - 10:58 AM
Picture so far look great Ross keep it up. Re-covered my dash in suede material last month and just finishing off the blue lighting for the dials. Looking forward to seeing more of yours
Mark
Thanks man!
Got any photos of yours in suede?
#25
Posted 27 May 2011 - 11:06 AM
Mark
#26
Posted 27 May 2011 - 11:08 AM
I am just waiting for a couple of bits to arrive (hopefully tomorrow) then can put it back together fully on sunday, will take a pic then and post it up
Mark
Sounds good
What are you doing regarding the indicator lights? I'm using the original 2 clock binicle mounted behind the dash, and I need a way of having green indicator lenses on the dash...
#28
Posted 27 May 2011 - 11:43 AM
I have a 3 clock set up mounted behind the dash the same way as yours, I have fitted these in my dash surround and taken the bulb section out of the back of them allowing the original indicator bulbs to light up the green bezel
If the makes sence
Yes, makes perfect sense, I was thinking this way but didn't know if it would work, thanks
#29
Posted 27 May 2011 - 11:49 AM
#30
Posted 28 May 2011 - 09:00 PM
