14 Or Even 15" Wheels With 4" 101.6 Pcd?
14 replies to this topic
#1 moonbug
moonbug
  • 13 posts
Posted 13 May 2011 - 11:55 PM
I have a mini based beach buggy with extended radius arms and am currently running 13" x 5" Ford stud Cobra Supaslots with adapter / spacer plates.
I'm looking for 14 or even 15" by 6, 7 or even 8" width with preferably mini stud pattern / PCD.
I am sure there used to be other cars with the same PCD (Viva?) but cant recall - can anyone shed any light?
Ideally, I want to find the biggest / widest slot mags I can (they are the only ones that look right on the car IMO) with this pattern - arch space is NOT a problem!
Help appreciated!
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 14 May 2011 - 06:59 AM
why not run wide re-rimed steel wheels
vw beach buggy's look cool with wide steels
#3 stu_cooper
stu_cooper
  • 70 posts
Posted 14 May 2011 - 07:56 AM
i duno bout the wheel but as bungle said id get some sick banded steelies made up they look awsome on any car including beach buggies
#4 Kerrin
Kerrin
  • 1,056 posts
  • Local Club: Manx Mini Register
Posted 14 May 2011 - 11:36 AM
Lots of other Austin cars had the same pcd as the mini.
Morris Marina, Minor and many others. Also hillman imp wheels fit.
Try somebody like Rimmer Bros for wheels, Wellers are made in 13" that would fit, offsets may be wrong but no worse than any other 13" superlite fiitted to many customised cars.
#5 siva1300
siva1300
    Just On Tickover
  • 6 posts
Posted 14 May 2011 - 05:48 PM
Help appreciated!
try raceways of donington. they can drill to suit but different style from mag slot. available in 7" 8" or 10" x 15
Edited by siva1300, 14 May 2011 - 05:55 PM.
#6 moonbug
moonbug
  • 13 posts
Posted 14 May 2011 - 11:06 PM
Cheers for the suggestions, I will look into these.
I took banded Imp steelies OFF the damn thing, but they were 12 x 8 and a bit iffy in their construction IMHO!
I was hoping to find some mags off one of the matching PCD cars from a similar stable, I can sort out the ET one way or another within reason as I have the luxury of no arches.
So, What else has the same PCD as a mini that I can use as a base to search out some period Mags?
Marina, Allegro, 1100/1300.....
#7 mikey72
mikey72
  • 321 posts
Posted 15 May 2011 - 12:13 AM
I think the MG used 14" wheels.
I'm just restoring a moonbug, been looking myself, but haven't got to that stage yet. It's on 13" Rostyles at the moment.
I had no paperwork, so I'll need to IVA it.
You been through that or did you miss it?
Edited by mikey72, 15 May 2011 - 12:32 AM.
#8 moonbug
moonbug
  • 13 posts
Posted 15 May 2011 - 08:15 AM
No, mine was fully V5'd when I got it, though I suspect the rules were a lot slacker back when it was done - mine still has steering rack bolted to the fibreglass (albeit with strengthening plates now) and seat belts same!
Good luck with yours, be interested to hear what you are doing with seats - mine have always felt ON the car, not IN it, and the main floorpan is stupidly high upso am planning to lower the floor and adjust the chassis accordingly so the seats are about 4-5" lower than now.
My hunt for 14-15" Mags goes on then!
#9 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 15 May 2011 - 08:17 AM
what does it say on the V5 ?
if it's already registered as a mini based kit car you won't need to IVA it
#10 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 15 May 2011 - 08:18 AM
http://www.mach5wheels.co.uk/
second one up from the bottom
they will build you any size wheel
Classic Car Wider Rim Replacement
Available for Vehicles:
Any make
Suitable Use:
On & Off Road
Offset:
Custom Defined
Construction:
Steel construction welded to your existing centres
We take your exising wheel and remove the centre section
A new steel rim to any standard width and diameter is then fitted with any offset required
Available in:
Diameter: 14,15,16,17,18,20 inch
Width: 7 to 10 inch
Delivery:
5-10 Working Days
Finish:
Bare Steel, Painted, Powder Coated in any RAL colour
#11 mikey72
mikey72
  • 321 posts
Posted 15 May 2011 - 07:58 PM
No V5, no chassis number, no reg number.
#12 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 15 May 2011 - 08:01 PM
then apply for the v5 using the reg number and see what it says when it comes back
your going to have to do this any way if you want to start using the car
#13 bmcecosse
bmcecosse
  • 9,699 posts
Posted 15 May 2011 - 08:03 PM
I bet Jon at JLH http://www.jlhmorris...d...at&catId=20 will do you a good deal. Morris Minor is 4" PCD. Tell him I sent you!
Edited by bmcecosse, 15 May 2011 - 08:05 PM.
#14 mikey72
mikey72
  • 321 posts
Posted 15 May 2011 - 08:06 PM
No reg number.
#15 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 15 May 2011 - 09:00 PM
missed the no bit, just saw reg number >_<
