Will This Pass A M.o.t
17 replies to this topic
#1 mr cooke
mr cooke
  • 278 posts
  • Local Club: Any
Posted 13 May 2011 - 06:42 PM
Can anyone PLEASE help me i am new to mini's and dont know alot
i have just had a 1985 mini it being of the road for 3 years or more
i am looking to get it though a M.O.T soon , do these floors look o.k or will they fail
#2 chubbyclubby101
chubbyclubby101
  • 127 posts
Posted 13 May 2011 - 06:45 PM
if you poke it with a screw driver and it goes through it will fail, basically any holes or excessive corrosion will fail
#3 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 13 May 2011 - 06:48 PM
if you can make a hole with a screwdriver in it, then no
if it is within 30 Cm spherically of a suspension mount or seatbelt mount and you can make a hole, its a failure, Check for holes
#4 mr cooke
mr cooke
  • 278 posts
  • Local Club: Any
Posted 13 May 2011 - 06:55 PM
are the rubber grommets ment to be there ?
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 13 May 2011 - 06:56 PM
Yes, they are to plug drain holes, however the outer of the two looks fairly corroded.
Well technically, there would have originally been two small metal rounds stuck in the holes, but over time they've probably been pulled to allow water out and replaced with rubber grommets
Edited by Guess-Works.com, 13 May 2011 - 06:57 PM.
#6 mr cooke
mr cooke
  • 278 posts
  • Local Club: Any
Posted 13 May 2011 - 06:59 PM
i think i will just put it in for its mot and see
#7 mini1976
mini1976
  • 408 posts
Posted 13 May 2011 - 07:00 PM
The rubber grommets are meant to be there.
If you can poke holes in the floor with a screwdriver then it may well fail (and is deffinately excessively rusty as the metal has lost its strength) I
f you can make holes within 30cm of the suspension then it will probably fail.
If you can make holes in the sills then they might fail as these are the structural.
#8 will_
will_
  • 201 posts
Posted 13 May 2011 - 07:50 PM
Dont use a screwdriver, top it lightly with a heavy object, even a small hammer, but you will defo make holes with a screwdriver.
You may be lucky if it doesnt go through, but it doesnt look too healthy.
#9 MiniMonty
MiniMonty
  • 1,802 posts
Posted 13 May 2011 - 10:59 PM
Will it pass an MOT - see the answers above but honestly I'd ask a different question:
Would you want to be sitting in a car with that level of corrosion when it's
hit at 65 by a boy racer's out of control Nova and smashed into a Land Rover ?
Best wishes
Monty
#10 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 13 May 2011 - 11:03 PM
Give them a good wire brushing and paint with hammerite or simular.
It will both protect them/slow down the rusting process and distract the MOT tester from poking at obviously rusty bits.
#11 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 14 May 2011 - 11:48 AM
some might say this is a bit of a bodge job.....i would rather 50 quids worth of fresh steel than some rust and paint..
#12 M J W J
M J W J
  • 976 posts
  • Local Club: not yet
Posted 14 May 2011 - 02:17 PM
It won't distract an MOT tester. They go straight for newly painted bits as they assume you are trying to hide something. My Granddad years ago put new under seal and seam sealant on so the first thing the MOT guys did was remove some to see what the floor pans were like. My Granddad was not best pleased but at least his car did pass.
#13 miniman24
miniman24
  • 1,696 posts
Posted 14 May 2011 - 03:57 PM
Really? I thought they wernt allowed to move/poke anything?
#14 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 14 May 2011 - 07:24 PM
MOT Testers have a regulated poker for proding suspect areas.
How can Hammerite be a bodge? Filler, fiberglass and seam sealer is a bodge!!!
I've been getting old borderline mini though MOT's for years - But what do I know!!!
#15 liam_italian
liam_italian
  • 1,417 posts
Posted 14 May 2011 - 07:33 PM
The question you should be asking yourself is "Does it deserve to pass and MOT?"
If you have any doubt that it will fail then you should get it repair properly, don#t bodge it because it will come back to bite you in the arse!
