How To Adjust A Door ?
16 replies to this topic
#1 ross k
ross k
  • 498 posts
Posted 12 May 2011 - 07:03 PM
right guys ive just fitted my doors after a respray but on one it all shuts but the top pushes to far into the frame and the bottom doesnt go far enough in the frame so sticks out past the quarter panel at the bottom this is the original door is there any way to adjust this thanks ross
#2 greensilver mini
greensilver mini
  • 585 posts
  • Local Club: HAMOC
Posted 12 May 2011 - 07:39 PM
i notice lot of doors are like that on minis even mine sticks out where your saying
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,039 posts
  • Name: Neil
Posted 12 May 2011 - 07:40 PM
Get your self a couple of plastic packers to put under the bottom of the door to stop it from dropping. Slacken the hinge nuts on the A post to move the door back in at the bottom. Be gentle and do not slacken the nuts too much, it might be handy to have another set of hands but you can do this on your own but it will take a little longer.
If this does not go then you may have to enlarge the A post holes or slot them. I have enlarged and slotted the holes on the A posts on Project Erm to get the doors to sit right plus a little bit of twisting and bending on the doors themselves.
Edited by sonikk4, 12 May 2011 - 07:46 PM.
#4 Nikral
Nikral
  • 274 posts
Posted 12 May 2011 - 07:42 PM
should have some adjustment shims located where the bolts of the hinge,s come thru. you can buy them on minspares or other sites.
#5 ross k
ross k
  • 498 posts
Posted 12 May 2011 - 08:17 PM
ok thanks for the help will try that i have packers but they move the door backwards and forwards dont they not in and out thanks ross
#6 sonikk4
sonikk4
  • 16,039 posts
  • Name: Neil
Posted 12 May 2011 - 08:36 PM
From your first post you do not need to put shims under the hinges, just undo the hinge nuts of the A post and readjust the door that way.
#7 mk1leg
mk1leg
  • 9,343 posts
Posted 12 May 2011 - 10:17 PM
Try this tip.................
It shows a mk1-2 door but the principle the same................ :P
#8 sonikk4
sonikk4
  • 16,039 posts
  • Name: Neil
Posted 12 May 2011 - 10:19 PM
That is a very neat picture. Where did you find that little puppy from??
#9 jonnyenglish
jonnyenglish
  • 229 posts
Posted 26 January 2014 - 08:08 AM
Sorry to revive but can someone tell me how this picture works? I'm not very clever :( but my doors rub summin chronic
Jon
#10 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,026 posts
Posted 26 January 2014 - 11:26 AM
Jon
The above pic is for mk1/2's, I geuss from you thread you have internal hinges. where abouts does the door rub? if they rub on the a-panel you'll need to put a shim in between the door hinge and a-post. If it's rubbing on the b-post then you'll need to remove shims (if you have them) to bring the door forwards.
Edited by alex-95, 26 January 2014 - 11:27 AM.
#11 jonnyenglish
jonnyenglish
  • 229 posts
Posted 27 January 2014 - 01:25 PM
its rubbing on the b pillar but there are no shims? ive raised the door as it had dropped at the top towards the b pillar but its almost like the doors to big?
thanks
jon
#12 riktanius
riktanius
  • 233 posts
Posted 30 May 2022 - 12:44 PM
Ive got some rubbing on the bottom closest to the B pillar. Like if the door is angled a bit.
Any suggestions?
#13 sonikk4
sonikk4
  • 16,039 posts
  • Name: Neil
Posted 30 May 2022 - 01:14 PM
Any suggestions?
If it’s rubbing along the bottom then you need some shims under the lower hinge to A post.
But what does the gap look like along the bottom of the door and the back of the door to rear quarter panel??
#14 riktanius
riktanius
  • 233 posts
Posted 01 June 2022 - 05:06 PM
All of my gaps seem large, there arent any obvious gap issues, but the paint is rubbing off the bottom of the doors
#15 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 June 2022 - 05:08 PM
Sounds like the door needs to come up.
Slacken the nuts, lift it up and retighten.
How to the swage lines look?
