Mini- Mini Restoration
#61
Posted 13 February 2013 - 05:01 PM
#62
Posted 13 February 2013 - 08:56 PM
#63
Posted 14 February 2013 - 08:07 PM
so before....
and after!....
#64
Posted 15 February 2013 - 09:30 AM
#65
Posted 12 March 2013 - 12:03 PM
also put a cheeky cheap bid on what was advertised as a 998 unleaded head i won it for £3.40 ish and it turns out.....
yes large valves and chambers .....yes its a 12g940 head.....
#66
Posted 12 March 2013 - 12:08 PM
#67
Posted 12 March 2013 - 12:18 PM
need a bigger de rusting tub....
lol, is it a sprite head tho with this thermostat housing or from an mpi/spi???
maybe i should post in tech help...
#68
Posted 12 March 2013 - 12:33 PM
the thermostat looks like a funny set up
#69
Posted 12 March 2013 - 04:30 PM
Nice work. I used the electroysis method of de rusting, but read about the phosphoric method too. I take it the acid does not damage the material, or do you have to keep an eye on it ?? I remember putting wheel nuts in vinegar and coming back to no nuts lol.
Great ebaying by the way !!
Graham
Edited by grahama, 12 March 2013 - 04:34 PM.
#70
Posted 12 March 2013 - 06:37 PM
#71
Posted 13 August 2014 - 06:50 PM
hahaha yup the same.... well the last year has been mad. Me and the mrs have had a baby. Been working hard for a premotion etc etc
well i was well up for mitp and couldnt get there due to bad weather so have been on here again looking at everyones projects, so i went and rolled the mini out the garage with intention to do some update worthy stuff... well i only stripped a few bits out ready to remove engine....but i took pics.......
so yea not much but i did label the wires too.......
well expect more updates now as i want a solid shell for mitp 2015......well one can hope
#72
Posted 15 August 2014 - 10:47 PM
Filler in the seam prob to hide the fact its wayyyy out....
and prob way out because for 1 the tear drop is bust and wonky...
and 2 the inner arch is miles away from the wing......
also i had to remove this awful bonnet pin.....
but when poking around, the bulkhead seams solid, even scraped where i thought was bad and bubbled up but seams ok...
will know more when i get a day off and get engine out and twisted knot wire wheel grinder on the lot....
not much but not bad for an hours work......also removed gear linkage and wiper motor and assembly :) just driveshafts now and i can lift her out;)
#74
Posted 20 August 2014 - 05:53 AM
#75
Posted 20 August 2014 - 09:02 AM
Yup, I just bought it as a spare and turned out to be a 12g940 :) its still sat in the garage next to the 4 pots tho ..... cant find a decent price 1275 block or cheap engine needing rebuild to have a play with
