Mini- Mini Restoration
#31
Posted 24 April 2012 - 04:20 PM
#32
Posted 30 April 2012 - 01:27 PM
wish me luck, im goin to attempt the removal of them bolts now......
#33
Posted 30 April 2012 - 01:50 PM
good luck
jordan
#34
Posted 30 April 2012 - 01:57 PM
#35
Posted 30 April 2012 - 07:48 PM
remember it always looks worse before it gets better
cheers
jordan
#36
Posted 30 April 2012 - 09:07 PM
if i was you just chop it all out back to solid metal and replace will new sheet metal, cut the end of the heel board off as it looks like it has past it fabricate one up and weld a stiffener on the new part for the subframe mount. but when welding new stiffener put the subframe back in to make sure you get it all lined up drill your holes and weld nuts to the stiffener for the subframe bolts. just a ruff way i would do it to help you out. or get and heel end panel but still use the subframe to line every thing up again
cheers
jordan
cheers mate, im going to get inner sills, 4 1/2" outer sills and heel board ends ordered .... just been and pulled subframe off and snapped 3 bolts out them 4 and had to saw the brake pipe off and found the rubber fuel pipe had a slice out of it from rubbing on the boot floor hole all these years.... didnt get any pics tho so will do that tomorrow, gotta try and clean the underseal off from everywhere to assess damage......... someone only undersealed after it rotted away........
also i think now the subbys off premature to my plans im going to try and accumilate parts to fully referb it maybe powder coat too, braded brake hoses, poly bush set etc..... we will see what the prices are like before i get carried away and how well it all welds up....... lol
#37
Posted 03 May 2012 - 02:27 PM
next the offside, no big holes yet and only the bottom bolt snapped, still needs cutting out and repairing tho.... just a case of cleaning everything back and seeing how much needs chopping out
the subframe looks virtually new, just needs the holes straightening and welding up where the tow bar was bolted too
guess ill have to strip it all down and find out how good the bits are!
#38
Posted 10 May 2012 - 09:37 PM
then replaced the hinge panel,
i also started welding the boot floor in too but no pic of that till tomorrow,
i also bought a complete inner sill and rear heal board repair panel for the ns so ill have a go at that soon too...all i can say is.... wahoo progress
dave
#39
Posted 10 May 2012 - 10:14 PM
#40
Posted 10 May 2012 - 10:21 PM
#41
Posted 11 May 2012 - 08:08 AM
#42
Posted 11 May 2012 - 03:05 PM
first of all just a pic of the subframe as its missing
also thres a clip missing off the radius arm, dont know what it does yet but theres a clip on the iother one lol
and today......
well welding the boot floor in was awfully hard so i cut it into 3..... then started welding...... what a mess it was as the floor was so thin then i pulled the back end out and spot welded it to the floor....and yes i know the bumper holes dont line up on the cheapo panels
also knocked this little panel up
Edited by mini_in_progress, 11 May 2012 - 03:05 PM.
#43
Posted 14 May 2012 - 07:57 PM
yes its seam sealer, and then i wanted to seal something so thought as i had the cheapo valence closers id weld them onto the valance and seal them up....
then i wanted to try out my other purchase and stop it rotting from the closers out and did the rear of the valence too
only a little update but hopefully ill have the boot foor done this week and have this on too :) ..... one can hope
dave
Edited by mini_in_progress, 14 May 2012 - 07:59 PM.
#44
Posted 29 August 2012 - 06:35 PM
well i cant wait to give you guys some regular updates....
and so i can move it ive had to bodge to rear subby on to move it so put the lenses in for a pic while i was at it....
cheers guys.......
a very excited dave!
#45
Posted 30 August 2012 - 07:55 AM
