Indeed it is, but the minisport ones are nasty chrome things (prob numberplate bolt lights) and nothing like the ones that where fitted to the works cars. They had aircraft instrument lights.
Pootles Latest Rebuild
#61
Posted 04 June 2014 - 07:10 PM
#62
Posted 09 June 2014 - 10:16 AM
I've spent an evening fighting with installing the pedal box (in and out 4 times before it was in right and the new clevis pins didn't want to go through all the way). Plus it seems its a pre 76 one and therefore doesn't have a brake light switch mount on it So i'm either going to have to make some sort of bracket or revert to the earlier type pressure switch setup
After struggling with it for a while, I moved on to sort the clutch hydraulics out. Got the clutch arm greased and the new clevis pin fitted, bolted up the salve and master and the pipe work
Was during this I noticed that the drivers inner wing was overhanging the front subframe, so that was stopping the subframe tilting and stopping the rear mount going in
Also cracked on with the alternator. Had to re-tap the holes for the bracket (as well as tap the hole in the bracket as it was slightly too small for the bolt), but I got the original alternator fitted up.
Whilst I had the tap and die set out, I thought I'd sort the threads out in the block for the engine steady. The new bolt I bought a few years back only ever went in about 1/2 way, so I dug out the tap and ran it in and out a few times and its still bottoming out the bolt about 10mm to early. I know it'll have a washer and the earth strap on it which will take out some of the gap, but it still seems to short.
Also got the oil pressure gauge T piece installed properly and removed the oil cooler (not really needed on a stg1 1098 ) and fitted teh braided pipe instead.
#63
Posted 10 June 2014 - 10:03 PM
some pic's
Had a frustrating day this evening, went to fit the new brake pipe from the master to the pressure valve, it was far too long and trying to tweak it to fit I kinked it so a proper pre-bent one from minispares was ordered
#64
Posted 22 June 2014 - 09:57 PM
I was supposed to have had all of last week off, but work needed me to do some hours so only ended up with 3 afternoons off and I manged to tweak my back too
But progress has been made. The headlights and indicators are now all wired up and installed, the holes are drilled for the choke and heater and they are now threaded through. I've sanded back and repainted the wheels
and got the tyres fitted to them :)
I've built the looms for the 2 works dash pods and for the speedo, fitted the hard lines from the master cylinder to the pressure valve, finally got the clevis pin on the brake master fitted (need to skim a bit more off the clutch one still), installed and wired up the brake pressure switch, finished off all the engine bay wiring, got the front subframes rear mounts fitted, got the shocks fitted and the new wheels fitted all round :)
He was supposed to be heading to Maks today, but with me tweaking my back and Rob (BOC) trapping a nerve in his neck, I'm now trying to sort out a recovery firm to take him down.
#65
Posted 29 June 2014 - 04:25 PM
Updated the list of jobs
front subframe
- Fit rear mounts ( Done)
- retorque top mounts (Done)
- buy/shim/fit front mount bolts (Done)
- Tighten/check lower arms and tiebars (Done)
- Tighten/check/grease upper arms (Done)
- Cut down bump stops (will do if needed once driven)
- fit front shocks (Done
Steering
- fit new column/ fit bolt (Done)
- adjust tracking/ fit lock nuts (Done although tracking needs final alignment once its settled(+)
- strip/clean/replace grease nipples/ regrease ball joints (done)
- build/fit drive shafts (Done)
Engine
- find/buy/fit pot joint (Mak supplying)/ FOUND (Done)
- tap top steady bolt holes/ fit top steady (Done)
- fit proper engine mount bolts (Done)
- fit lower gearbox steady (Done)
- Buy/fit eleccy dizzy (Done)
- buy/fit oil pressure sender (Done)
- set tappets/fit missing lock nuts (Done)
- service (Done)
- Fit exhaust
- Check gear linkage mount is correct way round
- Bolt up fan (Done)
- install rad (done)
- Buy/fit alternator / bracket (bracket fitted, old alternator fitted as the bearings sound good)
- Change oil cooler for pipe (Done)
- Fit speedo drive (Done)
- Fit speedo cable (Done)
- Fit throttle cable
Brakes
- Fit pedal box (Done)
- Buy/Fit brake MC (Done)
- Fit pressure dist valve (Done)
- Connect MC to Valve (Done)
- Connect Valve to front subframe (Done)
- Check front flexi hoses correct sides (Done)
- Bleed system
Clutch
- Fit clutch arm (Done)
- Buy/Fit MC (Done)
- Fit hard/flexi pipe (Done)
- fit Slave/connect (Done)
- Bleed/adjust system
Interior/wiring
- Finish /fit wiring main loom (Done)
- Fit headlight looms/ connect to main (Done)
- Fit lower dash rail (DONE )
- fit switch panel (Done)
- Cut hole for speedo in bulkhead box
- Fit speedo
- Cover Upper dash rail
- Fit dash pods
- Build looms for dials (Done)
- Drill out holes for choke/heater (Done)
- fit heater/choke cables (Fitted, but need connecting in the engine bay)
- fit heater (Done, but needs hoses fitting)
Bodyork
- Replace drivers sill
- sort hole under rear light
- sort hole Drivers rear shock mount
- Tidy/stone chip/paint sills
- touch up paint on A panel
- tweak/fit front seams
- paint front seams
- prep/paint rear valance
- paint bootlid
- repaint roof
- change back window seal
- change rear 1/4 window seals (Done)
- Trim front wings to suit tyres
Wheels
- strip tyres off rims (Done)
- blast /powder coat wheels (Done, but painted)
- tyres refitted (Done)
Plan is that we should be firing Pootle up tomorrow with working brakes and clutch
#66
Posted 03 July 2014 - 07:27 PM
Major step forwards today, I actually drove Pootle Granted it was only in and out of the workshop and I was sat on the floor, but the 1st time since Oct 2009 that I've done that :)
So to celebrate we finished off fitting the glass, fitted the speedo and then I fitted the harnesses and the seats went back in :)
#67
Posted 06 July 2014 - 08:27 AM
Had a mixed day at Maks yesterday. connected up the wiper motor to find it only worked on stg2, looking at its connector, that was pretty mullered so headed over to Moss to pick up a new one and 2 new wiper wheels too (as the old ones weren't to clever either), rebuilt it, put it back in and still only stg2 works Oh well, it'll pass the MOT like it so moved on.
Next up was the washers, plumed them in, fitted and wired in the pump and then went to find the washer bottle bracket. Can't find it anywhere and I know I had it before Pootle was delivered need to check in the garage today.
Then moved on to cut the hole for the speedo wiring to go through, hole saw went blunt 1/2 way through, so will have to bring my dremmel along and finish it with that.
Next job on the list, new bulb for the fog light, took the old one out, Hmm, looks quite a new one. So put it back together and had a look in the boot. Yup, not plugged in So thats sorted now, and the brake light switch is connected to the loom too so we are getting there with the wiring.
Although it does look like i'm going to need a new starter motor as it stuck again yesterday.
#68
Posted 10 July 2014 - 06:43 AM
Well, Tuesday night we cracked on through the final jobs and we are (as far as I can tell) ready for the MOT on Wednesday :shock:
And he PASSED
#69
Posted 10 July 2014 - 12:16 PM
#70
Posted 11 July 2014 - 09:31 AM
Cheers, just waiting for the tracking to be done and then I get it back tomorrow to crack on with the remaining job :)
#71
Posted 20 July 2014 - 01:42 PM
Ah yes, haven't updated this have I.
So, last Saturday was collection day. Pootle was taxed so all legal. Heading off there was a number of issues that came to light. 1st off was the throttle pedal, it was so high up that full throttle was level with the brake pedal (very painful driving home like that), 2nd off was the clutch. It had always been biting at the floor, (despite just about all the system being new), but it quickly deteriorated and got to the point where at a junction I was changing down into 1st before stopping and then sitting there holding it on the handbrake. 3rdly, it did get a bit hot when driving through Bath on a Saturday afternoon (cooled off to 90 once out on the bypass though and checked once he had cooled down as there was no water loss).
So, 1st off was the clutch. gave it a re-bleed, but no change, adjusted the clutch throw stop, no change. So went off and did some researching and there should be just over 1/2" of travel at the top of the clutch arm. Crudely measured, and I was getting about that so that lead me to believe that the arm is the next likely culprit. Quick check on minispares, under £20 for a new arm and top pin, so they where ordered.
Then on to the throttle pedal. 1st try was fit a different pedal I had (MPI cooper one), no difference. So I pondered it and came the the conclusion the only way to adjust it was to either bend the pedal (quite some way too) or slacken off the cable at the carb. A quick chat with Mr Pink on facebook later, and the cable was slacked off and the pedal in a much better position. Though it was confirmed that I needed the clip at the top of the pedal to stop the cable coming out.
The new clutch arm arrived yesterday, but the biblical rain put pay to any hopes of getting out in the garage. Might try and grab an hour later today though and see if that sorts it :) I've also picked up a new heater valve (as that is leaking slightly), a new summer thermostat and the clip that holds the throttle cable onto the pedal.
I have now made the CAD template (empty teabag box this time ) of the centre section of dash, just need to chop that out and fine trim it and then I can mount the passenger dash pod :)
#72
Posted 16 August 2014 - 05:12 PM
Some more progress :) Slow progress, but progress none the less.
Well, went to Mini 55 and came back with some goodies for Pootle. So on last Sat I had a go at fitting them. 1st up was cleaning back and repainting a early mk1 grill (non cooper type) which went pretty well (had to straighten it a bit too, got it mostly there) so once the pain was dry I headed out with that, a new tash and a new rear bumper.
1st issue I found was I had broken all the suitable sized drillbits for the screws for the grill but the tash wanted smaller screws (which I didn't have, but I did have some suitable pop rivets) so on I went. Just about had enough charge in the drill to get the 4 holes done and got it riveted on. Tried to line the grill up, 1st go and it looks like the profiles are different
will have to see how close I can get it when I screw it on.
So then on to fitting the new bumper. Splashed out and got a "fits better than the original Rover ones" from minisport for £40, and the fit is shocking! The studs were bent in slightly so had to tap them out , but even then they were really tight. Plus they still clash on the boot hinges and the shape of it is poor too (it is almost like a combination of a clubby and a round nose bumper), but its on so I shall move on to the next jobs.
Got out today and got the grill fitted, pretty chuffed now with how the front end is looking :)
So it was time to move inside and build the centre dash section. So armed with the previously made CAD template, I attacked some MDF with a jigsaw and headed out to trial fit. Went straight in So a couple of coats of satin black and the fuse boxes could finally be properly mounted :)
Still not worked out what the best method of securing the passenger pod though
Then it was time to fit the remaining goodies I bought in Japan back in 2010
1st off was the turtle trading cup holders, was a proper pain fitting them (and the seats had to come out so I could get into a position to fit the brackets), and I'm not 100% happy with the fit at the minute (the drivers side is sitting about 5mm to low), but otherwise I'm pretty pleased
So then back onto the oustside and fitting the petrol bib
And the important sticker
Edited by craig 1010cc, 16 August 2014 - 05:13 PM.
#73
Posted 07 September 2015 - 05:43 PM
But, I did get to the miniworld action day at castle combe. although I didn't venture out on the track as a number of issues arose on the few days before and the run over to combe.
The main issues being that on any heavy load temp gauge gets worryingly high (I think it is the needle is totaly wrong and is running lean, but it sits in traffic fine), the throttle has a stiff point and the rear tyres are trying to eat the arches really badly (which is odd as it never used to be an issue)
After combe, he has sat in my garage gathering dust, but getting the tax reminder through the other day, I decided to drag him out and take him for a run round the lanes before sorning him till the spring. The tyres are still rubbing (hence the rear arches are off), but the cold air seemed to help the temp issues and the throttle wasn't as sticky as I remembered
So, over the next few months, plenty of little jobs to be getting on with
So then it was on with all the other little jobs that needed doing. The most important being to raise the rear suspension so that I could actually drive him. Whilst the rear was apart I also wanted to repaint the inner arches grey (as they was still red) and I decided to give the rear subframe a lick of paint too. Raising the suspension stalled as I was without the 26 and 32mm spanners required (
All bolted back together and I had 1 final job this weekend I've been meaning to do for years. Painting the Group 2 arches body coloured. Not only does this echo the works rally minis, it is also common on the Japanese minis (which is what I've been trying to do my take on) so the paint was broken out and I'm pretty chuffed with the results
#74
Posted 05 October 2015 - 11:57 AM
So, with everything about ready, I texted the garage I normally use about an MOT late on a friday afternoon, giving me a week before Combe to get anything sorted, and hopefully get on the rollers to get the engine properly set up. Insurance was sorted (£90 for a year with brentacre, fully comp with agreed value!!)
I did wuss out on heading out on the track again (not having got to the rollers and the suspension is in desperate need of setting up), but was good to be back on the road again (Pic stolen from Icey as its an awesome one :) )
#75
Posted 06 March 2016 - 05:37 PM
