Pootles Latest Rebuild
75 replies to this topic
#46 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 19 July 2012 - 06:53 PM
Coming along slowly, but its progress. Be good on Sat to get him back home so I can just pop to the garage and spend 1/2 hr if the mood takes me rather than 1 1/2hr round trip to the lock lump before I've done anything
#47 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 21 July 2012 - 06:35 PM
Well, update 3 in a week :P
Yesterday was the final day of working on Pootle, progress made, gear linkage fitted (but only due to Gaz, I got it a bit wrong :P) but for some reason it only selects 1st and 3rd (more investigation needed I think. The exhaust manifold is fitted (cooper freeflow :) ) and the carb is bolted up. also fitted the front brake hoses and tightened up the tie rod bolts (must go round and bolt check the entire front subframe).
So today was the day that Pootle was coming home.
So 1st job was to get him outside
he was very grubby (the joys of parking in a barn) so a quick wash was in order
much better
Then an afternoon spent wiring the towbar in on Gary's new sprinter so we could tow him home (Cheers Gary :mrcool: which, apart from me wiring the indicators the wrong way round :shy: ) went pretty smoothly
So it was time to get him loaded up and head home
And now he is back, resting in my garage, waiting for me to get om and finish him :P
Edited by craig 1010cc, 21 July 2012 - 06:36 PM.
#48 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 09 February 2013 - 06:50 PM
You'll never guess what, I actually did some work for Pootle this afternoon :P Not a lot, granted, but its a start
Part of the interior that has been giving me the most trouble finalising the design has been the dash. I knew I wanted a retro look, and I loved the works dash pod's, but getting it laid out right has been a struggle. But I have finally got there (I think :lol: )
I've also been collecting more bits too. I wanted to have a set of stop watches on the passenger pod, and mini sport have recently started to make replica mounts. They offered them with or without the 'pea' lights (to iluminate them), but the ones they use are nasty chromed ones, not in keeping with the works look at all. So some time was spent researching what was originally used and it turned out that they are aircraft instrument lights and I managed to find a pair of MoD surplus ones for less than the price of 1 minisport one :)
So today I've been assembling the panel, fitting up the lights and trying the stopwatch (need to find another or possibly a watch so I have the time ;) ) and working out were to cut the pod
I've come to the conclusion that the easiest and neatest solution is to strip it right down and then to drill through and bolt everything through the pod and the mount
Anyway, we all like pic's
Pea lights installed
Stop watch in (need to adjust the position of the posts as its set of a 55mm watch and I've got a 50mm one)
and it roughly in position on the pod (taped up to stop scratches)
Hopefully tomorrow I should get this drilled and bolted and maybe even cut the Drivers pod for the oil, water and rev counter (Speedo is now going in the centre of the dash in a new panel to be built)
#49 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 10 February 2013 - 05:57 PM
Well, took it all to bits this afternoon to start drilling quite a few holes, and filing out a few of them to suit the watch. But its all together and and I'm pretty chuffed (Although i did manage to break the leg off the LED :( and I need to do the wiring)
#50 Minidarren83
Minidarren83
  • 1,207 posts
Posted 10 February 2013 - 07:49 PM
Hi I love what your doing and that the mini has changed so many times. What is the current colour you have it is close to what I want?
Cheers Darren
#51 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 10 February 2013 - 10:42 PM
I do have a habit of changing my mind a bit :P The current colour is rustoleum RAL 7001
#52 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 07 April 2013 - 04:56 PM
Well, another update, it must be spring :P
Its far to cold to venture out to the garage, so I thought it was time that I man up and cut the holes in the drivers pod for the dials. I've been putting it off for a while, but finally plucked up the courage to start drilling. 1st issue was the 52mm hole cutter I've got was blunt, so had to resort to chain drilling and filing out the holes with the dremmel (great fun). But I think it came out ok :) Still need to find/re-make the retaining straps for the dials, but I'm happy with how they look
So I got the passenger pod out of storage to get an idea of how they will look
Pretty chuffed with that :)
I've also brought another set of 10's with good Yoko A008's on them (should be arriving this week, but not sure if I'll just be using the tyres or the rims too), and will be putting in an order with minispares after payday to get the next batch of parts to start getting closer to the road soon :)
#53 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 06 May 2013 - 06:08 PM
Must be a bank holiday, some progress  :lol:
Well, stuck an order in to minispares the other week for the next stage of bits, so thought I should get on and do something with them :P
1st off was the new steering column, the splines had gone on the original and I replaced the rack as a precaution, but had been using one of Gaz's spares. So a new one was delivered and (after a trip out to buy the right sized socket to get the steering wheel off) it was stripped and rebuilt with ought any great drama :D
Fitting was another matter. 1st off had to clear the space infront so I could get him outside, but trying to get the new column onto the splines was a real struggle. Seems that they are closed up new and need spreading to go over but stay a snug fit. Its still not on 100% (need to dig out a suitable bit of wood and the lump hammer to help drive it home) but its fine for pushing in and out of the garage :D
Also had a play with the gears. Before we brought him home I could only get 1st and 3rd which I thought was down to the engine and subframes only being losely in at the mo, but some working through of the gear linkage has got all the gears  :proud:  1 less thing to worry about :D
So feeling on a good streak, decided to mock out the dash pods. 1st thing was to fit in place the padded lower dash rail, which looks like it'll need some of Rusty's magic to get it sitting right. Then out with the masking tape to hold the pods in place. Pretty happy with them, the drovers pod is sitting high and the passenger side is sitting low, but once the lower dash rail is sitting right then I think a lot of that will sort its self out. But the dials are sitting perfect in the line of sight from drivers seat  :gimme:  and the watch I've sourced works really well with the stopwatch :proud:
So, pics's now I guess ;D
#54 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 21 July 2013 - 07:23 PM
Shhhhhh, don't tell anyone but a little more progress has been made this weekend  :shhh:
Decided it was too hot to do battle in the garage, so over the last 2 days I've dragged out the wiring loom (which has sat in a big tub 1/2 finished for the last 18 months) and I've finished off replacing the bullet connector wiring extensions with proper colour coded soldered in ones and re-wrapped 90% of the loom (used about 20m of black tape so far :P). I've still got the 2 x 8 blade fuse boxes which will be mounted up on the dash by the speedo (final bit I've got to make on the dash is the panel that goes between the 2 works dash pods which they'll mount onto) and the wiring for the stereo, cigarette lighters and other dials will be on their own seperate looms which I'll build once the main loom is back installed. But its another thing (nearly :P) ticked off the list
#55 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 30 May 2014 - 09:40 AM
Well, since July last year, very little happened other than stuff piling up around Pootle and a general lack of Mojo. Over the last few weeks (partly fuelled by 'the of cars') and a small unexpected cash injection, I have been pondering over what to do with Pootle. And a plan has been hatched. Earlier this week I broke down all the jobs that needed doing (as far as I can remember :P) and I headed over to see Mak at Minitec in Keynsham (he did all teh restoration work on my MPI Cooper Si). Over a few cups of tea, we worked through the list and came up with a plan of action. I've got the week of 16th june booked off work to complete 'my list' and then on the 22nd June Pootle is off to Maks for 2 weeks and will return running and MOT'd :) So I stopped off at Somerfords on my way home from work with my initial parts list, more parts will be needed but should have the parts to get me going. front subframe - Fit rear mounts - retorque top mounts - buy/shim/fit front mount bolts - Tighten/check lower arms and tiebars - Tighten/check/grease upper arms - Cut down bump stops - fit front shocks Steering - fit new column/ fit bolt - adjust tracking/ fit lock nuts - strip/clean/replace grease nipples/ regrease ball joints - build/fit drive shafts Engine - find/buy/fit pot joint (Mak supplying) - tap top steady bolt holes/ fit top steady - fit proper engine mount bolts - fit lower gearbox steady - Buy/fit eleccy dizzy - buy/fit oil pressure sender (Oil pressure gauge pipe bought) - set tappets/fit missing lock nuts - service - Fit exhaust - Check gear linkage mount is correct way round - Bolt up fan - install rad - Buy/fit alternator / bracket (bracket bought) - Change oil cooler for pipe - Fit speedo drive - Fit speedo cable - Fit throttle cable Brakes - Fit pedal box - Buy/Fit brake MC (MC bought) - Fit pressure dist valve - Connect MC to Valve - Connect Valve to front subframe - Check front flexi hoses correct sides - Bleed system Clutch - Fit clutch arm - Buy?/Fit MC - Fit hard/flexi pipe - fit Slave/connect - Bleed/adjust system Interior/wiring - Finish /fit wiring main loom - Fit headlight looms/ connect to main - Fit lower dash rail - fit switch panel - Cut hole for speedo in bulkhead box - Fit speedo - Cover Upper dash rail - Fit dash pods - Build looms for dials - Drill out holes for choke/heater - fit heater/choke cables - fit heater Bodyork - Replace Passenger sill - sort hole under rear light - sort hole Drivers rear shock mount - Tidy/stone chip/paint sills - touch up paint on A panel - tweak/fit front seams - paint front seams - prep/paint rear valance - paint bootlid - repaint roof - change back window seal - change rear 1/4 window seals - Trim front wings to suit tyres Wheels - strip tyres off rims - blast /powder coat wheels - tyres refitted
#56 rooney123
rooney123
  • 114 posts
Posted 30 May 2014 - 05:30 PM
nice job look forward to up dates........................andy :proud:
#57 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 02 June 2014 - 06:32 AM
Cheers Andy :)
Managed to tick off a few jobs this weekend (lots of housey jobs to do and had to swap the bootlid over on the Ka).
Did get some more bits ordered though, so should hopefuly have most of the bits I need soon :P
I've dug out the wiring loom, spent a few hours looking at it trying to remember all I had done last year and I think its not far off ready to go in. 1 of the jobs stopping that was that the lower dash rail needed fitting, so this afternoon I dragged Pootle outside so I could do that and also have a bit of a sort through in my garage. Still lots to do on the sorting front, but its a step closer
#58 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 03 June 2014 - 09:43 PM
More progress, loom's 1/2 installed now, headlight looms are in and connected (although I need to change the side lights to suit the H4 headlights I've got) and my new elecy dizzy and coil turned up today as well :proud:
Of to Somerfords on my way home for the next batch of goodies (and one from minispares on route too), at some point I'll have to actually stop buying bits and fit them all  :lol:
Am dithering on wheels, do I stick with the reverse rims, or do I go with the deep dish 10x6 wellers I've got stashed away ;D
Edited by craig 1010cc, 03 June 2014 - 09:46 PM.
#59 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 04 June 2014 - 06:00 PM
sorry if this is a stupid question, what is a pea light???
YetI
#60 rally515
rally515
  • 3,848 posts
Posted 04 June 2014 - 06:02 PM
YetI
I think its one of those really small and specific direction lights for map reading or shining onto switches for rally minis, minisport sell them as monte carlo items i think.
