Hmm, been a while since I've updated/ done much
Well, Pootle is coming home now I've sold my Cooper as my garage is free, so no 60 mile round trip to the lockup to wok on him :)
Last week I spent a bit of time working through what bits I have and haven't got, found some I had forgotten about too :)
So the main task I wanted to get done was to get the engine all back together, so that needs the head actually bolting on
So 1st task was to lift the head back off (sat on the block to stop cack getting into the bores) and clean up the block face (after pulling the studs out).
Also whilst the head was off it was easier to fit the fuel pump blanking plate and the water pump :)
Then found out I couldn't find the bypass hose
Luckily there is an old rover dealer near by, and they had one on the shelf (they had to try about 6 different part numbers first
), was surprised how much stiffer it was compared to the hoses from Moss ect (and not the flexi type ones either)
So with that fitted and the studs back in the block we were looking like this
So then it was the turn of the head for a quick clean up
And on it went. Nearly made a clanger, was just about to start bolting it down when I realised that the pushrods were still in the card sheet I used to keep them in order :oops:
Also realised that I had left my torque wrench at home so its all just nipped up at the min and will be torqued down tomorrow.
So then went through and started to dummy build up the engine, more than anything to confirm whats missing and that everything fits.
So that left the engine looking like
Last night I made a bit more progress, got the head torqued down, so 1 more job completed :) Also bolted up the heater tap (with a new gasket of course
) and then tried to get the clutch arm out of the spare wok cover. Wasn't playing ball so had to leave that with some pen oil over it, hopefully be able to get it swapped over tomorrow.
So I fitted the clutch master and pipe work and refitted the brake master. Still got to work out how to bolt on the pressure valve and make the final pipe.
So will be back up for a few hours tomorrow evening, hopefully make a bit more progress
