1380 Track Toy
#121
Posted 23 July 2013 - 09:13 PM
#122
Posted 23 July 2013 - 10:19 PM
#123
Posted 09 August 2013 - 02:03 PM
Making a center console thing for the car will be covered in black leather
#124
Posted 10 August 2013 - 07:48 AM
#125
Posted 18 August 2013 - 06:41 PM
Engine wise I'm waiting to buy my med itch set up Monday heavy duty pressure plate and bonded and riveted ap clutch disc
Then I can send that to machine shop with flywheel to e lightened an balanced. Other than that all my engine is done ready to bolt up
But next payday next month I can order up my sccr clubman gears from Minispares along with gearbox recon kit and x pin diff .my mate is guna do my box for me for a drink so that's sweet as then I can order my cam kit xt profile from med will come with oil pump,valve springs,cam , vernier pulleys, followers, so at least I can put my engine together and put it in the car
#126
Posted 27 August 2013 - 08:28 AM
#127
Posted 27 August 2013 - 10:15 PM
#128
Posted 01 September 2013 - 07:50 AM
#129
Posted 04 September 2013 - 09:27 PM
#130
Posted 04 September 2013 - 09:33 PM
Get us a few pics
#131
Posted 07 September 2013 - 07:16 PM
#132
Posted 07 September 2013 - 07:52 PM
Cleaned all the bolt holes with a thread cleaner and stuck it in the hot wash for a bit along with my gearbox ready for the sccr gears to be fitted xpin diff and rebuild kit
Done ring gaps all at 12 thou top middle and bottom
All oil and water galleries cleaned out in block and water ways cleaned out in head
All ready for buying my cam and doing cam timing and crank end float
Also as seen cleaned all the block but its like its rusty I don't know why and I think it needs re honing as there is a bit of surface rust some how in the top of the bore
Edited by minilee94, 07 September 2013 - 07:58 PM.
#133
Posted 13 September 2013 - 04:31 AM
#134
Posted 23 September 2013 - 07:24 PM
#135
Posted 04 October 2013 - 07:33 PM
Got all my sccr gears , x pin diff , bearings gaskets water pump , piper xt cam , vernier timing gear , steel backed oil pump , cam followers , valve springs,auto to manual engine mounts , subframe poly bush kit , center oil pick up pipe .
Picking up my engine from bill Richards tomorrow cam timing done , CR properly worked out CR is now at 11.1 and gearbox all built up with a 3.44 final drive
All I need now is the correct piston rings because med kindly sent me a mixture of 1293 and 1380 rings
Picking up my engine from bill Richards tomorrow cam timing done , CR properly worked out CR is not at 11.1 and gearbox all built up with a 3.44 final drive
Edited by minilee94, 11 December 2013 - 10:01 PM.
