1380 Track Toy
530 replies to this topic
#451 minilee94
minilee94
  • 3,523 posts
Posted 27 January 2015 - 09:47 PM
Spi cooper block offset bored to 1380
Omega pistons
Arp bolts
Acl bearings bottom end
Piper 285 cam
Alloy vernier timing gear
Chilled iron followers
3 piece alloy push rods
Center main strap
37,29 valves 12g940 head (stamped 12g938)
Polished ported
11stud head ,double valve springs
Big valves
Weber 45 carb
Straight 6 inch manifold
Stainless polished manifold
Brand new x drilled nitrided , balanced crank
Med stage 2 clutch and flywheel ap bonded and riveted clutch
Straight cut gearbox , x pin diff , 3.44 final drive
11.1 compression ratio
Roller rockers
Hi torque starter
Aldon yellow distributor
Lucas gold coil
Med alloy crank damper
Turbo oil pump
Thermex alloy rad
Hi cap water pump
Electric fuel pump
Sytec fuel reg
All I can think of might of missed some out
Edited by minilee94, 27 January 2015 - 10:38 PM.
#452 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 28 January 2015 - 05:43 PM
Yeah. Pretty similar to my last 1380. I had the leaded head with bigger exhaust valves and Megajolt was the only real difference.
Never got mine on a rolling road though.
#453 minilee94
minilee94
  • 3,523 posts
Posted 28 January 2015 - 10:31 PM
Yeah I can't have a unleaded head due to my valves but I use millers lead additive
#454 Alex_B
Alex_B
  • 4,573 posts
Posted 28 January 2015 - 10:35 PM
How much did you spend on your crank? and where did you get it from? I am currently pricing up my big engine build and I need a crank thats capable of about a 9k redline (going bmw 16valver) and I think my current crank needs replacing due to the old flywheel ruining the tail. Thanks!
#455 Midas Mk1
Midas Mk1
  • 5,774 posts
  • Local Club: S.U.N.M.C
Posted 28 January 2015 - 11:02 PM
It is possible to have unleaded inserts, by 37,31 head has them :)
#456 minilee94
minilee94
  • 3,523 posts
Posted 29 January 2015 - 04:27 PM
All the company's swiftune , med etc have all said you can fit them but run the risk of them overlapping there selves or something and can fall out that's why none of the company's sell head with unleaded inserts in head with bigger valves like mine
And all engineering firms I spoke to about getting them fitted all refused to do it
And my crank I got cheap off a mate as he was building a turbo and didn't finish it and he then bought a med crank for his 7 port build
But new when I spoke to minispeed would of cost him about £500
And if your going to be redlining like that fit the med crank , nitrided x drilled , wedged crank about £495
#457 Alex_B
Alex_B
  • 4,573 posts
Posted 29 January 2015 - 04:52 PM
Excellent, I will look into that, thanks!
#458 minilee94
minilee94
  • 3,523 posts
Posted 29 January 2015 - 05:35 PM
No worries they fit that crank in all there race engines
#459 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 10 February 2015 - 01:58 PM
Revs kill the crank, especially 9k on a 3 bearing crank. I'd suggest steel crank and rods and some nice light Pistons. Which would be a lot more than £495
#460 summs116
summs116
  • 372 posts
  • Local Club: Mini 7 racing
Posted 11 February 2015 - 06:18 PM
i had a med crank and its good for 7.5k then it start to flex and touching valves on close tolerance engines.steel cranks the only option really. my sc3 swifty one been ok so far in my miglia
#461 minilee94
minilee94
  • 3,523 posts
Posted 11 February 2015 - 09:13 PM
If it don't spend it's life at 9k though should be okay surely
#462 Alex_B
Alex_B
  • 4,573 posts
Posted 11 February 2015 - 09:24 PM
If the pistons are touching valves at high RPM then no, any contact is bad. Once valves start touching the valve stems are gunna be stressed and that's just asking for shrapnel in the cylinder!
#463 minilee94
minilee94
  • 3,523 posts
Posted 11 February 2015 - 09:43 PM
Oh yeah I know that isn't good but I'm saying cranks surely can just instantly be f,d once they have hit 7.5k
Edited by minilee94, 27 February 2015 - 11:01 PM.
#464 minilee94
minilee94
  • 3,523 posts
Posted 27 February 2015 - 11:00 PM
Finally got some proper miglias cheap aswell :)
#465 minilee94
minilee94
  • 3,523 posts
Posted 28 February 2015 - 09:03 AM
Drove the mini ain't the otherday with abit of clear road and does it go ---- yes it flys really didn't think it was going to be that quick
