1380 Track Toy
#346
Posted 09 August 2014 - 07:32 PM
Few fuel leaks but soon sorted that need to be set up in the gun but it runs
There is almost piston hitting valve noise from the top / back of the engine any ideas
#347
#348
Posted 09 August 2014 - 11:38 PM
The mini runs :)
Good stuff, post up the vid!! hehe
could it be the roller rockers hitting the rocker cover?
#349
Posted 10 August 2014 - 09:34 AM
I don't know how to post videos
#350
Posted 10 August 2014 - 09:57 AM
#351
Posted 10 August 2014 - 10:12 AM
i would have thought a piston hitting a valve would do damage even with the lightest of taps, they arnt the strongest of things.
maybe put a bit of paint on the top of each rocker and while its wet give it a quick run then look for paint.
im glad your back doing your mini again, i just spent a hour reading through all your posts. I got to the same position with my project with loseing interest, i brought it with all the bodywork done and i payed to have it sprayed. i fitted engine suspension interior ect and last thing to go on were the wheels, the bloke before me hadn't lined up the body kit properly so they didnt fit. i lost all interest then and sold it sometimes i wish i hadnt, but it was too much of a blow to keep going with it.
Edited by AzMaN, 10 August 2014 - 10:13 AM.
#352
Posted 10 August 2014 - 10:27 AM
Out if interest what procedure did you follow when you started it up for the first time?
I was going to follow this guide when I'm starting mine:
http://www.minimania...edure_guide_988
Ian
#353
Posted 10 August 2014 - 10:38 AM
And I'm soon glad I never got rid of it now
Also Ian I just turnt the engine over with out the center lead on the dizzy to build up oil pressure once oil pressure was built up I just put the lead back on and turnt it over and it started just kept the revs up a little bit to keep it running and that was it
#354
Posted 10 August 2014 - 02:24 PM
#355
Posted 10 August 2014 - 02:31 PM
But it does have a misfire on cylinder 4
#356
Posted 10 August 2014 - 05:41 PM
#357
Posted 10 August 2014 - 06:07 PM
#358
Posted 10 August 2014 - 06:21 PM
#359
Posted 10 August 2014 - 09:14 PM
What you mean set up mate
The mixture and the correct needle?
#360
Posted 10 August 2014 - 09:53 PM
And it's a weber carb so it don't have a needle
Edited by minilee94, 10 August 2014 - 09:55 PM.
