1380 Track Toy
#226
Posted 31 January 2014 - 02:37 AM
Can the inline go anywhere
Also fitted crankshaft oil seal was a pain in the arse fitting they seem to be abit in the big side
Iv fitted seals before and was pretty easy but I messed up a crank seal before and £7 all in with postage etc on a seal is Sumink I don't want to go wrong many times lol
Anyway going to mark up the weber box tomorrow
And fit transfer case ready for my clutch and flywheel
#227
Posted 31 January 2014 - 09:49 AM
The inline filter should be fitted before the pump.
By crank oil seal I assume you mean the one which goes over the nose of the crank into the transfer gear housing before the clutch ?? There is a special tool for this comprising of a cover which sits over the primary gear splines and a sort-of tube type thing which is supposed to push the seal down square. I have wrapped the splines in wide masking tape making sure it's flat and wrapping on a couple of turns, then a light smear with oil and gently push the seal over.
Or do you mean the one in the timing chain cover ?? If so fit the seal into the chain cover first, it should just tap in gently with an appropriately sized socket or gentle taps with a hammer. Loosely fit the cover over the crank but don't tighten the cover bolts, slip on the bottom pulley and nip it up, then tighten the chain cover bolts.
Phil.
Edited by phil hill, 31 January 2014 - 10:02 AM.
#228
Posted 31 January 2014 - 10:09 AM
And yeah iv been told to wrap the gear in tape when I fit the case
And okay thank I wasn't to sure in the filter side of things
Thanks for the help
#229
Posted 02 February 2014 - 04:49 PM
#230
Posted 02 February 2014 - 09:42 PM
Just need a dizzy flywheel and crank pulley
#231
Posted 05 February 2014 - 06:56 AM
#232
Posted 05 February 2014 - 08:10 AM
#233
Posted 05 February 2014 - 04:57 PM
Edited by minilee94, 08 February 2014 - 10:05 AM.
#234
Posted 05 February 2014 - 06:08 PM
top project mate loving the work
#235
Posted 06 February 2014 - 04:18 PM
Very nice project keep up the good work
#236
Posted 08 February 2014 - 10:06 AM
#237
Posted 12 February 2014 - 08:40 PM
#238
Posted 12 February 2014 - 09:09 PM
#239
Posted 12 February 2014 - 09:27 PM
eh?
#240
Posted 15 February 2014 - 05:14 PM
And it don't matter if tax man sees the forum the rebate is tax back from tools that iv spent over the last 2 years
