1380 Track Toy
#166
Posted 06 December 2013 - 07:47 PM
#167
Posted 11 December 2013 - 10:10 PM
Mr calver says on a fast road max end float is 6 thou
But I will need to wait till after as once I have got my tool tax rebate through then I can buy my st3 med ultralight flywheel kit and ap racing clutch plate
Ordered a few bits from dsn classic a brake servo plate , oil pressure relief bolt , and a stub take off for the head got alot more to buy yet :)
That's about it till after Xmas really have a good one don't eat and drink to much :)
Edited by minilee94, 11 December 2013 - 10:10 PM.
#168
Posted 15 December 2013 - 01:31 AM
1275 spi offset rebored to 1380 running 11.1.1 compression ratio
Brand new crankshaft ,x drilled , nitrided
Omega cast 7 cc dish pistons
Arp big end nuts and bolts
Med stage 2 cam kit alloy vernier cam gear
Straight cut gearbox - std helical drops all bearings replaced rebuilt box center oil pick up
Stage 4 head , polished ported 12g940 (12g938) head ,11 stud 36ml inlet ,29ml exhaust , rebuilt , double valve springs
Weber 45 straight 6 inch manifold (alloy)
Acl cam bearings
Acl big end and acl main journal bearing
151 roller rockers
Hi capacity water pump
X pin diff , 3.44 final drive
Med stage 2 ultralight flywheel and ap racing clutch and verto pressure plate
Maniflow manifold
Straight pipe to 3" fletcher exhaust
Thermex or equivolant alloy rad with electric fan
Facet solid state fuel pump with regulator
Edited by minilee94, 15 December 2013 - 09:58 AM.
#169
Posted 16 December 2013 - 07:53 PM
impressive list
#170
Posted 17 December 2013 - 04:34 PM
The only stuff left fr me to buy is
Pot joints
Clutch and flywheel
Rockers
Rad
Oil cooler and pipes
Weber box
And a few bits like dsn thermo stat housing
#171
Posted 21 December 2013 - 08:29 PM
Lining up a few carbon fibre bits for after Xmas , weber box , rad cowling , and rocker cover
Also buying my rockers and flywheel and clutch set up after Xmas
#172
Posted 21 December 2013 - 10:32 PM
#173
Posted 21 December 2013 - 11:15 PM
#174
Posted 01 January 2014 - 12:18 AM
Any excuse lol
Ordering 151 roller rockers , performance pushrods , crank thrust washer , and head stud kit
Then once got my tool tax rebate I can buy my med stage 2 clutch and ultralight flywheel kit
#175
Posted 01 January 2014 - 01:16 AM
#176
Posted 01 January 2014 - 11:19 AM
Mate the push rods are not needed save your cash. Get some arp rods bolts with the cash.
I've noticed the price of ARP rod bolts rocketing recently.
Just received mine from a company on eBay for £73.
Ian
#177
Posted 01 January 2014 - 11:24 AM
Also I'm not guna get arp head studs I'm going for mini spares own designed head stud kit basically same as arp
And yeah rod bolts are dear I was lucky I got my brand new , x drilled nitrided crank with arp rod bolts off my mate for £350
And I don't fancey budgeting on the pushrods either really they do non genuine ones but it says do not use on performance engines
Edited by minilee94, 01 January 2014 - 11:28 AM.
#178
Posted 01 January 2014 - 11:42 AM
I run std crank, and push rods on my eng and they have been fine.
#179
Posted 01 January 2014 - 11:51 AM
I only got the crank as it was a good deal
#180
Posted 01 January 2014 - 11:52 AM
