Revolution Wheels And Sleeved Nuts
Posted 25 April 2011 - 04:35 PM
I had a rough trip on the H2H yesterday. I suspected poor balance on new 12 revolution wheels or a twisted/worped tyre.
When I checked by jackin up and spinning the wheels they were massively off centre. Tyres and balance were ok.
Removed one and found that the sleeved nuts supplied with new wheels were 14mm diameter and hole in wheels were 15mm.
Has anyone heard of this as a little research shows that th correct nuts are 14mm or larger for 13s, 11/16 think, approx 17mm.
Help, can't use the car for splash dash if I cannot fix and sods law I sold the old ones yesterday.
Matt
Posted 25 April 2011 - 04:47 PM
Posted 25 April 2011 - 04:58 PM
I wonder if they are revolites as opposed to actual revolutions and as so need diffrent size nuts?
Matt
Posted 25 April 2011 - 05:04 PM
throw them away and start again
Posted 25 April 2011 - 05:51 PM
The one revolite I have does say revolite on the back.
Make sure the shank of the sleeve of the nut is not sticking through the back of the rim as they won't nip up.
All my revolutions have been the same size nuts, mini spares do them if they are geniuine Revolution.
Posted 25 April 2011 - 06:23 PM
Thankfull they are not too far away in southam.
Thanks for the help.
Matt
Edited by Tinkerbelle, 25 April 2011 - 06:34 PM.
Posted 25 April 2011 - 09:29 PM
Not having the faintest idea where you live, as I am an island bumpkin, I would point you towards one of these instead of MWS, Isnt there a Mini Specialist in Southam? or have I got the wrong end of the country.
Posted 26 April 2011 - 07:54 AM
Iain
Posted 26 April 2011 - 07:18 PM
Went to MWS today and they are mini 12x5 but looks like someon decided to drill the stud holes out snd ruinned them. Ebay resolution already sent!Are they by chance Revolutions for a different car? Maybe 4x100 PCD and someone has bodged them onto a Mini by using undersize (for the wheels) wheelnuts?
Iain
Matt
Posted 27 April 2011 - 04:31 PM
Iain
Posted 28 April 2011 - 07:56 PM
Posted 28 April 2011 - 08:13 PM
Posted 29 April 2011 - 09:56 AM
It depends what type of Revolutions they are as their are 3 different size wheel nuts that fit the different types over the years. Are they 5 spoke Revolutions or 4 spoke Revo's? There were 45degree 60degree & the other I cant remember but the tapper on the nut is different. Try giving mini spares a call and explain which you have, they should be able to sort you out.
Revolutions (at least all that I have seen or owned) have parallel sleeve nuts, with a flat washer to locate and nip up the wheel to the face of the hub. Perhaps some of the RFX type had more standard taper wheel nuts but not sure.
Shame you are having trouble with them, I shan't be buying any more Revs secondhand as every set seems to have a problem.
Perhaps it is possible to sleeve the standard nuts to fit the wheels or have custom wheel nuts made.
MRA could be worth a call but also Jonspeed make up wheelnuts.
Posted 29 April 2011 - 09:59 AM
(they are taken off my car because i downsized to 10s - not because i had any problem)
Posted 29 April 2011 - 02:58 PM
