Each ball joint will take a couple of strokes from the grease gun but then the lever on the gun goes solid. I eventually managed to get a little grease out from under the dust shield of one joint but it took a LOT of pressure on the gun. The other three just won't accept any more grease no matter how much pressure I apply. The nipples are free and the fact that each joint accepted grease initially but then doesn't take any more has me puzzled. It's almost as if I've lapped them too well and the grease can't flow around the inside of the cup and out the top.
The joints came from Minispares but I can't remember if they were genuine or pattern parts. They took a while to shim and lap in but eventually went together very well, not excessively tight but just right.
Does anyone have any ideas?
Edited by SolarB, 25 April 2011 - 03:46 PM.
