Sticking Brake Pedal
Posted 24 April 2011 - 10:56 AM
The brake pedal on my 1989 Mini Flame is sticking when i push down on it. When i push it down the piston pushes the pads out into the disk as it should however when i release it the pedal stays in the same position and the brakes stay locked so im thinking its the piston causing the problem
Any ideas?
Posted 24 April 2011 - 11:07 AM
Posted 24 April 2011 - 11:31 AM
My 1990 Mayfair was doing the same thing. I found that after braking the barkes were sticking on, but if I put my foot under the brake pedal I could flick it up and release the brakes, so I put my issue down to a sticking pedal. Greasing the pivot didn't make much difference so I've temporarily lashed up a return spring to brake pedal.
Ah thats could be a good temporary solution however i must locate the problem before i do any serious driving
Posted 24 April 2011 - 11:53 AM
Posted 24 April 2011 - 12:00 PM
Yeah i will get it to the garage and strip it and give it a good cleanIt will be the pedal sticking on the rod. You'll need to take the whole thing apart and clean it all up.
thanks for the advice
