200 bhp mini ?
#46
Posted 15 February 2006 - 09:40 PM
#47
Posted 16 February 2006 - 11:59 AM
i have a question about mini williams, is it a company or just somethign you decided to call your mini etc
#48
Posted 16 February 2006 - 10:48 PM
It all started off with a friend saying how the clio williams also has the gold wheels and blue paint, the idea came up from there really, funny though as the paint on the wheels and body work are not from the clio.
MW
#49
Posted 17 February 2006 - 12:49 AM
#50
Posted 20 February 2006 - 06:38 PM
however, the engines will last about 2 meetings @ drag wars
( which is y i asked )
then itll need a rebuild and poss sum replaced components
good luck if ya going 4 it
#51
Posted 20 February 2006 - 08:23 PM
#52
Posted 05 March 2006 - 05:53 PM
The only way to have this sort of power and retain a practical car would be to change to a different angle unless you are prepared to get one off high load best materials imaginable componants to maintain drivability.
Its not quite a task of Veyron proportions though.
#53
Posted 06 March 2006 - 11:46 AM
Saying that, 18k was spend on it!
ENGINE
1293cc metro turbo block, metro turbo lightened, balanced, cross drilled. wedged crank, lightened balanced con rods, omega 18cc dish +0.20 pistons, avonbar t2 piper cam, duplex timing chain, mospeed booster large chamber head,7.5:1 compression ratio, 31mm exhaust valves, 35.7mm inlet valves, modified garret t3 turbo, 10 psi avonbar actuator, 1 3/4" metro turbo carb rebuilt with needle, jet and springs for relevant boost, k+n cone, bosch metro turbo fuel pump, malpassi adjustable fuel pressure regulator, 2 " maniflow down pipe, lambda sensor, 2" stainless system with single box, boxer tailpipe, electronic ignition, four core radiator, 60 amp alternator, mocal 13 row oil cooler, pace inter cooler
GEARBOX
straight cut close ratio metro turbo box, 1.1 straight cut drop gears, cross pin 4 pinion diff, 3.1 final drive ratio, ultra light steel fly wheel and back plate, grey clutch diaphram, ap racing race clutch plate
BRAKES
Drilled and grooved front discs, green stuff pads, mintex rear shoes, goodridge hoses all round
SUSPENSION
spax adjustable shockers, hi lo adjustable ride height. full polyurethane bush kit, 1.5 degree camber front and back
WHEELS/TYRES
minilights mk2, pirelli drago tyres
INTERIOR
konig reclining front seats in leather to match car, door cards and rear seats trimmed to suit, grp custom one off dash board, isolotta rep steering wheel, black carpets and headling, additional gauges moulded in dash for boost, oil temp, pressure, water temp and air fuel ratio.
EXTERIOR
mk3 shell, resprayed in seat yellow, zeemax rep bodykit, rear spoiler, zeemax modified bonnet, m3 door mirrors,halogen angel eye headlights, clear lenses all round, lots of chrome.
ICE
7"screen with fitment for a PS2, alpine head unit, four s type 6x9" speakers, s type 12" sub, alpine amp. power invertor for PS2.
It is also for sale...
#54
Posted 06 March 2006 - 11:48 AM
#55
Posted 06 March 2006 - 11:49 AM
the car is in immaculate condition with out a mark, i had the car rolling road tuned at peter baldwins were it made 185bhp but the run was aborted due to water loss, which was just a loose pipe in the end, but the engine will be pushing over 200bhp when its next on the rollers i know it will, as i still had 4 psi to go to take it to 20 psi, and the engine was sittig sweet were we stopped
#56
Posted 06 March 2006 - 06:03 PM
its in progress!
#57
Posted 07 March 2006 - 12:46 AM
#58
Posted 07 March 2006 - 09:30 AM
#59
Posted 07 March 2006 - 11:47 AM
#60
Posted 07 March 2006 - 05:24 PM
VW have done a twincharger type thing recently and it works well for them at least. i think the biggest problem would be fitting a supercharger and a turbo charger in the engine bay
Rember the Lancia Delta S4 of 1986? 600bhp from a 'Blown' 2 litre engine
