I am James, son of Dave from DSNClassics/Retrosport and this is my mini pickup, which was a Birthday present from my parents for my 13th birthday back in May 2005. It first past its MOT in December 2009 (It has been to a Bingley Hall and Mini in the Park and also had a minimag article on it sometime last year.) Since then It's been through a lot of install changes but this next one should hopefully be the real deal sound wise!
It is going to be a few weeks until I am back home from uni in America and will get to crack on with this build properly but there is lots of design work and equipment pictures coming in that I can add to it in the mean time.
This is where it was found:
Having stripped it:
After sand blasting, attaching a steel support frame and then having cut the bottom floor away, before re-welding all the pannels (70%+ of the panels had to be replaced:)
After all the welding was done it was then dipped at SPL in Birmingham which removed all the sealant etc, followed by their dip-primer process.
Back from the paintshop:
Edited by senior800, 22 April 2011 - 12:54 PM.
