How To Remove Idler Gear Bearing?
11 replies to this topic
#1 rich1889
rich1889
  • 285 posts
  • Local Club:
Posted 22 April 2011 - 11:13 AM
What is the best method of removing idler gear bearing?
#2 mike.
mike.
  • 6,176 posts
Posted 22 April 2011 - 11:42 AM
See if this helps: http://www.theminifo...showtopic=48044
#3 Ethel
  • 25,919 posts
Posted 22 April 2011 - 11:49 AM
The purpose made tool. Careful dremelling & collapsing with a punch or welding on a nut to pull with a bolt are also tactics.
#4 tommy13
tommy13
  • 878 posts
Posted 22 April 2011 - 11:50 AM
If you have a welder, put an M10 bolt or similar, head down into the bearing and weld it to the bearing lip. You can then put a large socket over the bolt and with a nut and washer on you should be able to pull the old bearing out.
#5 rich1889
rich1889
  • 285 posts
  • Local Club:
Posted 22 April 2011 - 12:04 PM
not the simplest of jobs then eh?.... bugga.... why do blind bearing pullers cost so much money?!
#6 NZMini1275
NZMini1275
  • 227 posts
Posted 22 April 2011 - 08:28 PM
I have just managed to remove mine. I first tried the Guess-Works method as posted in the link above. Unfortunately this just pulled the top lip off leaving me nothing to pull on. Had to buy a dremel and cut and grind little bits and use a punch to bend and snap them off. Just when i was going to give up the remaining piece popped out.
#7 rich1889
rich1889
  • 285 posts
  • Local Club:
Posted 23 April 2011 - 01:25 PM
i just used guess works method with the bolt and washers off an ultimate engine steady and i worked perfectly! just had to grind down a bit of the washers and it came out no problems
#8 david_rachel
david_rachel
    Starting My Mini Up
  • 1 posts
  • Local Club: The 1100 Club
Posted 09 October 2016 - 01:17 PM
I've just used the link to remove my bearing....came out with no trouble.   :proud: The casing was warm still from having removed the outer race of the 1st motion shaft bearing, so that may have helped
Actually used a pair of M10 stainless steel washers with 3 sides of each ground down.
#9 Spider
  • 14,840 posts
Posted 10 October 2016 - 08:57 AM
Here's some factory info on the First Motion Shaft Outer race, their advice is much the same for the Idler Gear Bearing.
Heat is not recommended.
IdlerGearBeraingRemovalWM_zpsszavfbdn.jp
#10 MacGyver
MacGyver
  • 1,027 posts
Posted 10 October 2016 - 11:16 AM
Because they have to be accompanied by a specially trained dog... 😀
#11 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 10 October 2016 - 02:25 PM
I use a blind puller and a little heat.
Although they are all buggers getting off!
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 10 October 2016 - 04:31 PM
Just for the record, this post harks back to the days when I looked after the FAQ's, and as items were submitted I posted them, can't take any credit... Think the original post came from TurboMinis...
I too have a blind bearing puller...
