12g1316 Cylinder Head
Posted 21 April 2011 - 01:16 AM
Posted 21 April 2011 - 01:40 AM
http://www.mra-minis...gine-single.htm
Posted 21 April 2011 - 06:54 AM
if its to bring emission down string the head and clean it all up de coke it and lap valves in
Posted 21 April 2011 - 08:56 AM
Posted 21 April 2011 - 10:39 AM
I have the fittings to charge the cylinder with air and the spring compressor that fits onto the rocker stud. If you can't charge the cylinder with air to prevent the valves from falling you can feed several feet of small rope into the cylinder. You can find the procedure on the internet.
Posted 21 April 2011 - 11:20 AM
Thank you for pointing me toward the valve stem seal. I wasn't sure if it was that type or the o-ring type.
- Rope trick is a cracker works a charm (was a bit incredulous until I tried it) , but use new nylon thread / rope plastered in fresh oil to avoid a) any fragments being left in the bore and b) ease of extraction and pull the engine through by hand to ensure it's nicely compacted in the bore
Posted 21 April 2011 - 11:30 AM
Posted 21 April 2011 - 11:49 AM
For the seals, contact Todd Miller on the Austin America forum. Todd sells Viton versions of the seals. They are very high quality. You can reach Todd through his web site:
http://www.austinamericausa.com/
Feel free to tell Todd I sent you his way.
Regarding doing this with the head in place... I've done it. The compressed air trick is not likely to work. It will only work if the valve spring caps and keepers/collets have not stuck to each other. It is quite likely that they have. Rope down the bores DOES work.
Regardless, if your valve guides themselves are worn, replacing the seals will only give you a temporary improvement. After a few weeks the oil burning (particularly after decelerating in gear) will be back.
EDIT: by the way Keith, if you find you need help with your Mini, you are not too far from Steve Gibbs in Newport News. Steve runs a Mini specific service shop and is a long time friend.
