Broken Flywheel Puller!
10 replies to this topic
#1 charm_muppet
charm_muppet
  • 77 posts
Posted 14 April 2011 - 11:16 AM
Hi there, I have just been attempting to remove my flywheel (engine out)
However, I have broken the head off of the centre bolt, the whole setup is very very tight. How am I going to remove the puller from the flywheel?!
Matt
#2 Chris_R
Chris_R
  • 399 posts
Posted 14 April 2011 - 11:36 AM
Slacken off the three bolts you've attached to the flywheel a quarter of a turn at a time until they move freely, then just remove it. The centre bolt shoulodn't actually engage with the thread on the crankshaft so isn't actually attached to anything.
#3 charm_muppet
charm_muppet
  • 77 posts
Posted 14 April 2011 - 11:48 AM
Ive just realised that I havent removed the keyway washer! I had removed the locking washer only. Doh!
I have tried loosening the 3 bolts but they are pulled into the puller itself.
If I cut one of them is it likely to shatter?
#4 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 14 April 2011 - 11:50 AM
Don't cut one- if they are under a lot of pressure it could fly apart and hurt you... Can you get mole grips on the centre bolt REALLY tight and slowly undo it?
#5 charm_muppet
charm_muppet
  • 77 posts
Posted 14 April 2011 - 11:52 AM
I doubt i'll get them on tight enough :lol:(
Can't believe i didnt see the keyway washer...
now what....?
#6 TopCatCustom
TopCatCustom
  • 1,134 posts
Posted 14 April 2011 - 11:54 AM
How about heating up the centre bolt and knocking with a hammer so it slowly collapses, you shouldn't have to belt it hard if red hot and it should softly move, you can just bend it out of the way so the other 3 go slack.
#7 charm_muppet
charm_muppet
  • 77 posts
Posted 14 April 2011 - 11:57 AM
will i be able to heat it enough with a blowtorch? Migt be easier to heat the 3 outer bolts as they are thinner?
#8 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 14 April 2011 - 11:58 AM
now what....?
Just some thoughts. You could weld a nut or suitable lump of metal to the bolt & try & use that to unscrew the centre bolt. Alternatively file or grind some flats on the bolt enough to get a spanner on. But as mentioned before the puller is under alot of pressure so just take it steady & prepare for the worst if it pops off.
#9 TopCatCustom
TopCatCustom
  • 1,134 posts
Posted 14 April 2011 - 12:03 PM
If you heat the 3 bolts under stress they could twang apart and leave a red hot bit of metal sticking in you somewhere, not advised, I doubt you would heat the centre bolt hot enough with a blow torch to be honest anyway.
#10 charm_muppet
charm_muppet
  • 77 posts
Posted 14 April 2011 - 12:04 PM
How about cutting the centre bolt has much as possible then striking it to make it bend?
I'm going to give that a go.
Will let you know how I get on
#11 charm_muppet
charm_muppet
  • 77 posts
Posted 14 April 2011 - 12:24 PM
Success!!
I cut the centre bolt and struck with cold chisel and lump hammer, took some doing but its out.
Thanks for all of your help
Matt
