Fitting A Hydralic Hand Brake, Any One Done It.
#31
Posted 05 February 2014 - 07:22 AM
#32
Posted 05 February 2014 - 06:46 PM
It can not be done with one way valves. I have already explained how it can be done, and why I would not even consider doing it.
By the way, in an earlier part of my career, I was doing flight safety analysis on aircraft brake systems, and initial design of the hydraulic system for a couple of medium to large turboprop airliners, so I can tell you that in a powered hydraulic system it is difficult, but not as difficult as doing it in a hydrostatic system on a car.
#33
Posted 05 February 2014 - 07:02 PM
I realise this now, I thought my initial idea was brilliant and it would nearly work it's just that the back brakes would stay on when you either pressed the foot brake or pulled the handbrake - not ideal, would be a bit annoyingIt can not be done with one way valves.
#34
Posted 05 February 2014 - 07:06 PM
As you brake before the corner, take your foot off the brakes but the rears stay locked on, you lose control and spin the car and go backwards through a hedge!
Yup, a bit annoying!
#35
Posted 05 February 2014 - 07:13 PM
Or spin completely and go through forwards? Dunno which I'd prefer?
#36
Posted 05 February 2014 - 09:17 PM
I'd prefer going backwards, so you don't slam your face in your steering wheel
#37
Posted 05 February 2014 - 09:21 PM
Safer going backwards if you've got headrests!
I wonder if you could do something with a front drum set up on the back? Use a pair of cylinders for the foot brake, and a set for the handbrake ????
Ultimately though, it wont be something I'll be doing, I'll just use the cable operated handbrake
#38
Posted 06 February 2014 - 01:26 PM
You could install dual hydraulic actuation, with two wheel cylinders operating in parallel on the same set of shoes. It does give a lot of problems, how to squeeze them in, and the need to re-shape the shoe ends, for instance, but in theory it can work. Basically, two bores in the one cylinder casting would be the way to do it. Not so good, in fact rather poor, would be an internally divided cylinder, with one piston fed by the footbrake, presumably on the leading shoe, and the other the handbrake, on the trailing shoe. It would just need a specially machined cylinder body, and a larger hole in the backplate to admit two hydraulic feeds and two bleed nipples.
Or indeed, as suggested, TLS front brake backplates, bearing in mind that braking in reverse would be abysmally poor (my drum braked Minis were extremely poor in reverse) and the handbrake does have to hold the car in reverse on a 1 in 3 gradient. And how do you fit the mechanical handbrake? Possible, but messy.
Or, two-pot calipers and tiny discs, pointless for braking performance, but a neat way of getting two distinct systems per wheel. I don't know if you can get twin pots which also have a mechanical handbrake system, which will still be legally required, but it is an interesting possibility.
I assume that the hydraulic handbrake, or even fiddle brakes, would be reserved for off-road use only....
How about spring-applied, hydraulically released brakes?
#40
Posted 04 March 2014 - 11:49 PM
#41
Posted 04 March 2014 - 11:56 PM
#42
Posted 15 February 2016 - 04:01 PM
How did this end up going for you?
Not sure what the relevance of how long it takes you to wrap your hand around it if it's as an aid for parking on a steep hill.... As mentioned earlier in this thread, I'm fairly sure you can get a hydraulic handbrake the the foot brake runs freely through when the handbrake is "off", but uses the feed from the main cylinder to brake the rear wheels when used.
If I'm parking on a hill. I'd leave it in gear as a matter of course. Even handbrake cables can snap...
Sorry to drag up an old thread, but I was searching with relation to fitting one for auto test/rally use.
#43
Posted 15 February 2016 - 04:35 PM
we used to use Hillman Imp Brake Mcs and just plumb them inline on a single circuit brake system. I just needs to be after the pressure regulator.
Bing (1)
