Year: 1974
Description of problem (please be as in depth as possible): Hi all!
Usually I'm pretty good with Mini issues but this one has me stumped... Basically it's started making a loud "hollow" blowing / sucking noise under acceleration and is very down on power at higher revs. I checked the exhaust over thoroughly yesterday and found it was blowing slightly at the Y piece, but I've fixed that and it's still making the noise. Doesn't seem to be blowing at the manifold either so I'm now 99% sure that this is some kind of induction noise.
I checked the cone filter over and blew it out with some compressed air but it all seems OK. The dash pot was dry so I topped up the oil in there which helped a little bit with the power but the noise is still there.
Any non-standard parts that might be involved with the problem?
MG Metro A+, K&N cone filter, Maniflow LCB system, modified head
Thanks in advance for any light you may be able to shed on this confusing issue!
Edited by SmellyGeekBoy, 11 April 2011 - 10:20 AM.
