998 Turbo Advice
Posted 08 April 2011 - 11:03 AM
Posted 08 April 2011 - 11:11 AM
The distributor needs a very different advance curve to prevent 'detonation' which would quickly destroy the pistons.
For the cam, you certainly don't want one with too much valve timing overlap, as that would require very high revs and turbocharged engines don't need to rev so high. An MG Metro cam would probably be fine, although something like a Kent 255 might give the best power band.
You need to really 'read-up' on forced induction technology and the various calculations involved with it. You will find that the maximum boost pressure will influence the other considerations. Do your homework first. You might consider a supercharger on a 998 as that used to be a good solution when the Shorrock unit was correctly fitted (Google 'Shorrock Supercharging').
Posted 08 April 2011 - 11:40 AM
Posted 08 April 2011 - 11:50 AM
To get the compression low enough you will have to either use dished pistons or have the chambers in the head enlarged. Your also going to need a turbo hif 44. Have a look on turbo-minis.com and turbominis.co.uk. Look at turbo-mini first a lot of info and its very easy to understand. Tuen go over to turbominis and become very confused. Lol, there is so much info abailable on both sites. You may also want to consider buying tuning the a-series by david vizard.
If you use the 12G295 head with the standard 28cc chambers on flat-top pistons you get around 9.4: CR, this is perfect for your aimof 100bhp whch should be achievable on on around 10psi.
All the standard engine and gerabox stuff will be fine with the exception of the diff, a crosspin would be advisable.
I have found that the Minispared mega range of pistons are decent for turbo charging, but the 20773 and the later slipper pistons are fine as long as you are sensible with boost.
As said the dizzy needs to be in the bin, mapped ignition is the best solution, and the HIF44 is the easiest route, using a metro plenum.
Finally, the MG cam is perfect, but a standard cam would also work.
Posted 08 April 2011 - 11:44 PM
I Have done alot of research into forced induction and have looked at other 998 turbo projects and i do grasp the basic idea but need a bit of help for certain bits as im struggling to find a simple explanation i can understand.
So the standard distributor should be ditched, is the megajolt kit the best way to go or is there a cheaper alternative as from goin by ebays prices its an epensive bit of kit.
Would you get away with using a standard diff or is ugrading a must?
I am still a bit lost with the oil feed and return to the turbo. is the return just going back to the sump? where would i get the feed from?
Also as for the intercooler, where is the best place to mount it, also does the intercooler pipeing connect it directly to the carb as im not too sure
And can the fuel pressure regulator and fuel pump be sourced from another car instead of a metro turbo.
Any ideas where i could source some of these parts, like the carb, inlet manifold fuel pump and regulator?
Posted 09 April 2011 - 12:00 PM
