So the estate has been off the road now since the tax ran out at the end of October as I want to be getting on with some jobs over the winter.
I've re-built the rear brakes with new drums, shoes and springs. Just need to adjust the correctly now. Also fitted new shoes and springs to the fronts but couldn't fit the new drums over the shoes, even with them adjuster wound as far back as possible. Still need to adjust these also.
The exhaust has been re-fitted and lengthened (welded) to fit the LWB better than before, was a bodge really. This should allow me to navigate speed bumps more comfortably. I need to sort the rear ride height now this is done.
I've spent most of my time in the interior. It started off like this, black vinyl front seats, blue material rear bench with tatty carpets.
So I stripped out the old carpets thinking I would find the dreaded brown stuff but a pleasant surprise there will only very little surface rust. This was rubbed down and the whole floor painted with black hammer paint and covered with a little sound deadening to reduce panel resonance. All floor holes were plugged and sealed.
I randomly found what looks like carpet underlay in the garage which must have come from my old project, this was trimmed and fit the floor perfectly. Hopefully this should reduce the road noise.
Then it was time to fit the brand new carpet set I won on eBay months ago for £15
I thought it will be a perfect fit but did require quite a lot of adjustment. It's not perfect but much better quality than the old one and looks good enough for me. the pictures don't do it justice.
The rest of the interior plans are:
New front and rear black door cards in vinyl
New dash in vinyl
New steering wheel
New gear shift and handbrake gaiter
Re-trim the spare rear bench I have in vinyl
New locking seat belts
New boot liner
Then other jobs such as:
Front and rear subframe mount replacement
Brake adjustment
Steering rack replacement
Changing the rear window seals
Etc.
Etc.
