Steering Rack Removal
Posted 31 March 2011 - 08:35 PM
Need some advice...
Im ready to remove the steering rack to replace with new. U bolts off, steering column nut & bolt off, wheels, hubs, driveshafts etc all off. The steering rack is now loose. The front subframe mounts are out. Towers and rear floor mounts still in place.
Is it best to drop the subframe? Or life the car body?
If dropping the subframe is preferred, whats the best way to put the chassis on stands? I tried using 2 old wheels (with tyres on) underneath the front floorpans, then lowered the car. It sort of worked (with the theory of spreading the weight as much as possible), but am just worried about damaging the floor pan because of the weight of the front subframe and engine! There isd no way i want to jack the car up on my outer sills!
ive thought about putting the subframe and engine on axle stands and then lifting the car chassis, but again am worried about bending or damaging part of the front end.
Any help would be appreciated.
Posted 31 March 2011 - 08:53 PM
Posted 31 March 2011 - 11:30 PM
I lowered the subframe using the trolley jacks and slipped out the rack, was still very tight. Worth noting I also undone the top engine steady.
Hope this helps.
Posted 01 April 2011 - 07:33 AM
i plan to use my engine hoist to lower the frame and use a trolly jack for guidance.
i will jack the car as you mention.
any issues with seperating the steering column from the rack? is this splined? put lots of penetrating oil on it as its been like that since 1992!
Posted 01 April 2011 - 02:51 PM
Posted 01 April 2011 - 07:15 PM
What's the best way to loosen it as ive tried brute force and the floor pan was bending...eek
Posted 01 April 2011 - 07:50 PM
I tried removing mine today,there is no engine or subframe in at the front,ive undone and removed the blot from the bottom but the colum wont come out.
if you've taken out the pinch bolt, tap a wedge into the split at the bottom to loosen the splined area.
Sam
Posted 01 April 2011 - 10:25 PM
Sam
I tried that with a screwdriver,maybe ill try a bigger scredriver tomorrow...lol
Posted 02 April 2011 - 06:11 AM
Posted 02 April 2011 - 08:55 AM
