Jacking Points
20 replies to this topic
#16 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 29 March 2011 - 05:30 PM
i made a block that is the same angle as the sill where my roll cage fits and jack it up on them, i have drilled holes into it so it doesnt slip and can locate on to the rollcage bolts.
its brilliant and will never buckle or bend the floor:) if you have a roll cage i would definatly advise this:)
Edited by MiniclubmanGT, 29 March 2011 - 05:30 PM.
#17 daveeeeee
daveeeeee
  • 684 posts
Posted 29 March 2011 - 05:38 PM
Hi, I use two jacks, one on each side of the subframe. Then use two long planks of wood running down the length of the car to spread the load on stands.
#18 almarsh132
almarsh132
  • 390 posts
  • Local Club: Medway Mini's
Posted 29 March 2011 - 06:02 PM
Thanks for all the advice! might weld some 4mm steel plate on subframes as reinforced jacking points :lol:
#19 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 29 March 2011 - 06:09 PM
I think you'll find that the subframe is plenty thick enough without the added plating.
#20 analogue_radio
analogue_radio
  • 4,897 posts
Posted 29 March 2011 - 06:12 PM
Stick a small plank of wood between the jack and the subframe to prevent damage to the paint & help spread the load and you'll be fine..
#21 almarsh132
almarsh132
  • 390 posts
Posted 29 March 2011 - 06:13 PM
Yeah i always put chocks of wood on the axle stands, better safe than sorry!
