:nugget: Well it was only a short conversationHello All, Happy New Year.
I am that bloke
Cheers Mini Sprocket.
correct not two manifolds (where would you put that lot?) just the one.
I need to correct you on one bit Mini Sprocket, it does work and always did, although in a fashion because, like you say, i had no driver for the 2nd injector.
I drove the car with it on, no leaks, around the block a couple of times, just leak & 'fouling' checks, of which there were none.
I have never really pursued much, the need for an amplifier which is all it needs to run the second injector from the original ecu trigger.
I made this assembly 7 or 8 years ago! with standard parts original for the spi.
an opinion for you: - the advantage of carbs is limited to the fact that they allow the engine to draw what fuel it wants at low revs in particular, hence the ability to run wilder cams that in an injected form that 'gives' fuel whether needed or not, causing tuning difficulties as a result of cam overlaps etc.
This advantage is quickly affected by the rolling road tuning limitations of the likes of (no matter how well set up) su's, which would always be the best carb'd choice for most, for historical and originality/practicality reasons. They are not able to be adjusted for incremental rev range & load fuelling, only 'near' fuelling due to the millions of jets not being accurate for each individual engine.
Peter Baldwin (you either know him or you don't) set up my car as spi, to 95bhp with more accurate fuelling than a later setup with twin 1 & 1/2" su's, although with su's i had a slightly wilder cam and about 5bhp more.
can't post pic, it won't let me, i enjoy cars and bikes more than computers, the file is too big i think.
