1982 Austin Mini - Project Who?
852 replies to this topic
#706 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 20 February 2019 - 09:05 PM
Today I started pulling out the parts I have had soaking in the Citric Acid solution.
Nice and gunky:
The cylinder head is coming up nice:
Just a few stubborn areas:
Once its done I am going to hit the water galleries with a Jet Washer to try and clear as much crud out as poss.
Here are the valve springs and caps all oiled up, they'll need a but more of a polish up but I just wanted to get them oiled up for now:
And lastly the Crank and Water Pump pulleys looking almost new:
Not sure whether to paint the pulleys or have them zinc plated, I wonder how they were done originally?
#707 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 22 February 2019 - 06:31 PM
Took the 12G295 out of the acid today for a final clean up:
Here it is after a little more scrubbing and a jet wash with clean water, then oiled up:
#708 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 22 February 2019 - 06:38 PM
Next I started to prep the 12G940 1275 Head for the acid dip.
I hadn't managed to get the thermostat sandwich plate and housing off as the bolts were seized. I tried some heat and gave them another go but in the end I had to cut the bolts off. The Thermostat housing inlet pipe had been snapped off so it would need replacing anyway:
I got the thermostat housing off (after a battle) but the sandwich plate is going to another problem. I also have the problem of getting the bolts out :-(
#709 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 22 February 2019 - 06:54 PM
That heads come up really well! I had the same problem with my sandwich plate, I cut it with a hack saw into 3 parts and cut a bit out and then rotated them which might loosen the studs.
#710 GraemeC
GraemeC
  • 7,437 posts
Posted 22 February 2019 - 08:02 PM
You might find that after a bit of a soaking the bolts and sandwich plate start to ease their grip
#711 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 25 February 2019 - 09:20 PM
Well Alex, you were correct.
As soon as I had cut the sandwich plate and moved each part there was enough friction to rotate the bolts and in this case there was no murphy's law where one remained stuck.
#712 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 25 February 2019 - 10:05 PM
Well I pulled the 12G940 from the bath and cleaned it up today.
All pretty clean?
The tachometer on the donor car read 55K and I have every reason to believe that this is the original engine. Very little coking to be honest.
With a little bit of work this could be a good head.
The exhaust valve guide bosses are flush but the inlet ones are not, for better flow I think I read somewhere about removing them?
#713 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 29 September 2019 - 07:25 PM
Slight deviation from recent posts on here, although I seem to have started a separate thread on the engine build which is now shown in my signature.
Went to Castle Combe Mini Action day and treated Dolly (The MINI) to some inner door trims, the windows have been rattling for the last three years :-)
#714 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 30 October 2019 - 08:43 PM
Latest acquisition:
Been looking for a spare Front Subby for a while and picked this one up locally. Plan is to strip, clean and paint it, then build it up off off the car with new / refurbished parts to include a 7.5 Disc Brake setup, get the geometry sorted ready to go into the Mini when the new Engine is ready. Also an opportunity to freshen up the Engine Bay.
#715 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 25 January 2020 - 02:10 PM
Well no updates on here for a while, mainly whilst I have been researching and starting the engine upgrade. I started a new thread just on the Engine which I will probably continue with as opposed to adding everything back in here. What I will do tho is put some info on here once it's all together - next few years at this rate :-)
So pop over to the 1275 Metro Engine Project for the latest updates.
#716 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 15 April 2021 - 06:34 PM
Although this is part of the engine upgrade it's not info on the engine build, so I thought it would be best to pop this here.
As part of the engine upgrade I picked up a spare subframe, thinking it would make the swap over quicker as if the subby was all prepped, I'd only need to paint the engine bay.
It's been hanging on the wall for over a year and thought I'd make a start:
First up some measurements to make sure it's straight.
Iv'e got the measurements in a folder that I printed out years ago, can't think where they came from?
I went around with some chalk and marked a few areas that need straightening, and then attacked them with a hammer and some dollies:
Then using some carboard templates I made up a couple of support pieces to strengthen the front Tie Bar mounts:
Then after cleaning of the metal I clamped and tack welded:
Then welded:
Then cleaned up:
Dressed down and sprayed with some zinc primer:
#717 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 16 April 2021 - 06:26 AM
Lol. I just did the same on my subframe, although I also welded some gussets for the outer corner.
Will post some pics.
Nice job anyway!
#718 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 16 April 2021 - 06:56 AM
Nice job anyway!
Thanks, welds weren’t as clean as I’d have liked, I’m blaming my new welding helmet, as soon as I strike the arc it’s as black as a witches proverbial 🤣🤣 Need to play with the settings.
#719 alex-95
alex-95
  • 6,025 posts
Posted 16 April 2021 - 08:54 AM
Looking good! Are you going to re-drill the engine mounting hole 1/2" further forward to fit the HIF44 carb in more easily?
#720 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 16 April 2021 - 09:45 AM
Hmm, now that's not a mod I have heard of before?
Need to look that one up, before it gets painted :-)
