1982 Austin Mini - Project Who?
852 replies to this topic
#661 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 13 April 2017 - 08:05 AM
Looks great mate, I bought one of those ariels from halfords to, I ended up taking it apart just using the long strip which is mounted up under the top dash rail (+ an added arial wire inside the door rubber) with the majority of the arial cable, so you can't see it.
Thanks Alex
So you got rid of the powered bit?
I have wired mine up to a spare switched 12v left over from re-wiring the Radio and In Car PC.
#662 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 13 April 2017 - 08:11 AM
I just read through your blog on building the system.
Very interesting.
Thanks Ben - I have too many projects on the go!! Just about to go out to the garage and weld up a frame for a Robot using an old powered invalid chair. May end up being a DALEK but I have tried to calculate the costs in advance this time and currently it will just be a working chassis :-)
I have just been looking through my phone - keeps telling me its running low on storage - still got about 3 years worth of photos on it, many of which are from this project. When I look back at what I have done I keep thinking - What the Hell!!!
Still she (Dolly) is on the road and I love getting her out for a drive - Beaulieu here I come (FINALLY).
#663 Owens
Owens
    Just On Tickover
  • 5 posts
Posted 13 April 2017 - 10:34 AM
Love this interior, the Ipad dash looks great!
Puts me in mind of the Remastered Mini David Brown Automotive have just announced.
Think I prefer your DIY approach though!
#664 1984mini25
1984mini25
  • 8,785 posts
Posted 13 April 2017 - 01:23 PM
Thanks Alex
I also had one of those widescreen mounted aerials. Connected it up and worked fine with the cable duct taped to the a pillar. But as soon as I rerouted the cable down inside the a pillar along with the front to rear loom, it picked up nothing but static. So as I didn't really want some messy wires taped to the side of the windscreen, I went back to using the old one on the front wing.
#665 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,040 posts
Posted 13 April 2017 - 04:58 PM
Thanks Alex
Yeah got rid of the power bit all together, it didn't make any difference at all.
#666 RT2002MCS
RT2002MCS
  • 18 posts
Posted 14 April 2017 - 06:08 PM
Wow, what a long road you have been travelling to get to your current stage, great dedication that is being rewarded with a mini you have built.
#667 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 21 April 2017 - 08:41 PM
Thanks for the kind words  :proud:
#668 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 21 April 2017 - 08:56 PM
Finally got the door cards on. Actually I was told to get on with it by the missus  :proud: She is coming to Beaulieu with me and said it needed to be finished!!
I lost the photos of making the door cards, cutting and sticking on the carpet underlay but here is a pic of the card finished before fitting:
I used HomeBase spray glue to fix the underlay to the board and the vinyl to the underlay. Then a staple gun around the edges.
I gaffer taped up all the main holes in the door:
I dug out my clips from Mini Spares:
And put all the clips in:
I made a bit of a mistake with the first door card. I didn't mark the holes for the door handle and had a mare trying to locate the screw holes so on the second one I placed the handle in position.
And here it is fitted:
My foam was much too thick (9mm) and the handles were a bit tight and the surround for the door lock does not fit in so I may have to drill it through and use some self tappers.
The doors don't rattle now.
#669 andyt
andyt
  • 375 posts
  • Local Club: cooper register
Posted 22 April 2017 - 05:45 AM
Loving your work coming together very nicely, i too have Beuliea as a target to get to, can't wait!
I'm looking for a radio ariel that I don't have to drill into the body where did you get yours?
Andy.
#670 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 23 April 2017 - 06:03 PM
Andy.
Thanks Andy.
Aeriel was a windscreen aerial from Halfords - only cost £3.99.
Get cracking!!
#671 andyt
andyt
  • 375 posts
Posted 23 April 2017 - 07:07 PM
Cheers, i will!
#672 Albino_Hedgehog
Albino_Hedgehog
  • 341 posts
  • Local Club: Solihull Mini Classic Club
Posted 13 May 2017 - 01:40 PM
Loving the build so far!!
#673 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 14 May 2017 - 03:04 PM
Many thanks :-)
#674 Albino_Hedgehog
Albino_Hedgehog
  • 341 posts
Posted 12 June 2017 - 02:11 PM
Did you manage to get to the show this weekend just gone as planned?
#675 alex-95
alex-95
  • 6,040 posts
Posted 12 June 2017 - 07:58 PM
I didn't actually get any pics of your car, but was good meeting you and seeing it in the flesh.
